Temp higher than before
Old Aug 6, 2009 | 01:29 PM
SortaRican's Avatar
Default Temp higher than before
I've noticed that my car is running slightly hotter than when I bought it. It only used to get up to 2 bars and now showing 3 consistantly. I have a cai & test pipe, could either of these cause it to run hotter?
Also I noticed over the weekend when driving with a buddy a smell that I thought was my serp belt melting a sort of rubber burning. Checked teh belt and nothing. Checked around the motor and all appeared to be fine. No leaks or obvious signs of damage. I put the car away and haven't brought it out since. I'm going to get into it this weekend while doing a trans/diff flush. Come to think of it the smell was a cross between burning rubber and old trans fluid. My trans fluid is only about 13k miles though.
Any suggestions?
Old Aug 6, 2009 | 01:37 PM
captainbk's Avatar
Mine runs 3 bars all the time. I thought they all did
Old Aug 6, 2009 | 01:50 PM
cj0's Avatar
cj0
did you recently change your clutch?
Old Aug 6, 2009 | 01:51 PM
CHRIS_HONDA's Avatar
unless somebody did the modifry modify?
Old Aug 6, 2009 | 02:01 PM
ComposiMo's Avatar
Once cool, how is the fluid level in the radiator? Is there sufficient fluid in the overflow as well?
And mine runs at 3 bars also.
Old Aug 6, 2009 | 02:23 PM
Subalahoo's Avatar
3 bars too. did you change your coolant recently? and are you sure its a rubber burning smell not a plastic or electrical burn
Old Aug 6, 2009 | 02:55 PM
yarbrough's Avatar
3 bars here also. Check your radiator around the cap for a crack.
Old Aug 6, 2009 | 03:06 PM
slidzhapply's Avatar
3 bars here as well
Old Aug 6, 2009 | 04:58 PM
SortaRican's Avatar
Hmm ran at 2 for a really long time when I first got it. I'll check teh rad tomorrow.
As far as electrical burning... Dear God no! I had a Porsche that was the king of electrical fires and I don't want to deal with that ever again. Is there a common electrical short that I never heard of?
No new clutch.
Old Aug 6, 2009 | 04:59 PM
cj0's Avatar
cj0
replace air cabin?
