Gateway S2000 Owners Members for St. Louis MO and area.
AEM CAI issues
Old Nov 28, 2007 | 08:17 AM
Diz's Avatar
Diz
Default AEM CAI issues
So my charcoaled colored AEM CAI keeps disconnecting where it connects in the middle of the 2 pieces..I'm talking on a daily basis.. so last night I had enough and replaced it with the stock airbox.. I miss the sound of the CAI but was getting tired of having to fix the CAI most of the time daily.. any solutions anyone on how to get the thing to stay together???
Old Nov 28, 2007 | 08:52 AM
Doug1627's Avatar
New connecting sleeve?
Wrap the end of the tubes in duct tape or something similiar to make the pipe into a bigger diameter?
Smaller hose clamp?
Old Nov 28, 2007 | 08:58 AM
jimmij's Avatar
I think that you need a support at the bottom. Gravity is working against you. I think when we did ryan's that there was a bottom support so that it would not fall down.
Old Nov 28, 2007 | 09:08 AM
8BALL's Avatar
Sounds like you are missing a support brace.
Dougs suggestions should also work
Old Nov 28, 2007 | 10:04 AM
ryanfeldman's Avatar
jimmi is correct. there was a bolt and ruber piece that is attached from the car to the intake at the bottom of the cai for support.
Old Nov 28, 2007 | 10:10 AM
jimmij's Avatar
And you doubted me?
Old Nov 28, 2007 | 10:38 AM
Diz's Avatar
Diz
Thanks guys for your info maybe if it warms up again, i'll try and mess with it again.... untill then i got a bad ass black airbox taking up the front of my engine bay
Old Nov 28, 2007 | 03:56 PM
rehile's Avatar
Based on your description, you likely lost the soft mount hardware. There should be a rubber 'cylinder', a couple washers, and a long screw/nut used to hold lower section of the CAI.
Hope you did not lose the bracket. Apparently they've been know to break on occaision. See note from 'prostreetonline' website:
Q: What does the soft mount do and how important is it?
A: The majority of AEM air intake system designs mount to a vehicle in two locations. One mounting location is to the engine at the throttle body and the
Old Nov 28, 2007 | 06:55 PM
Diz's Avatar
Diz
I got it used and unfortunatly never got the soft mount...Is there a place to order this piece?
Old Nov 29, 2007 | 04:56 AM
Doug1627's Avatar
I might have one. Its a slim chance of finding it but I will check this evening.
