Gateway S2000 Owners Members for St. Louis MO and area.
I've lost my mind
Old Sep 15, 2005 | 06:02 PM
folex187's Avatar
Unhappy I've lost my mind
I think I've finally lost my mind. First off, I bought the AEM Uego ($350) to make sure my A/F was right at 5psi. Welded ($25), installed($12 for relay, wires, etc), and A/F a-ok (worth 1million USD). Car runs good, pulls great, and sounds great.
On an impulse buy, I purchased the Tech2 pulley which yields 7psi actual boost (after the aftercooler) it was only $100 with the belt from a board member who hooked me up.
Then I got to thinking I might as well do it right and put some kind of engine management. I was going to go emanage blue but it is just too limited. AEM is out of the question due to the constant headache and no OBDII so I finally settled on the Ultimate Emanage ($500) + PNP Harness ($200) + A/F Cable ($20).
After reading another 10 threads, I decided I would be better with larger injectors ($200 used + clips (??) + RC plugs ($30).
On the 24th I'm going to KC to have the new pulley installed and a street/dyno tune ($350-450).
So, once again, the belt is off and the car is N/A again until the 24th. How crazy am I? Are there any support groups I can attend?
Old Sep 15, 2005 | 08:05 PM
hyedracyl's Avatar
You're right Alex, you need help...
Greg
Old Sep 15, 2005 | 08:14 PM
rehile's Avatar
Greg
HAHA
I got to see/hear your ride when it's knocked up!
Old Sep 15, 2005 | 09:52 PM
folex187's Avatar
Greg- have you considered checking your a/f since you installed your kit? I would recommend you do so with the stock kit. Mine was all over the place and needed a few rotations to make it optimal.
Old Sep 16, 2005 | 04:48 AM
AdamHondaS2k's Avatar
So your car is not good for this weekend?
Old Sep 16, 2005 | 06:59 AM
Fapout's Avatar
Wow. That's going to be the shit after it's all done! How many other people around STL are supercarging their S? I thought I read some threads about different people buying superchargers. What's the status on all those?
Old Sep 16, 2005 | 09:29 AM
8BALL's Avatar
I think we have 5 or 6 in the group now
Old Sep 16, 2005 | 10:31 AM
folex187's Avatar
The car is running good for this weekend. Actually, if my wire harness comes back it can be FI in about 3 minutes. I had to remove the ESM box for the emanage so there is nothing to clamp the MAP voltage right now.
Old Sep 16, 2005 | 04:48 PM
jimmij's Avatar
Ok here is your therapy.
Any time that you feel the need to spend more money, give me a call. I will talk you through which parts I want you to buy for me. That way you will not feel any guilt about all the money that you are spending on your car.
Old Sep 16, 2005 | 04:56 PM
folex187's Avatar
Don't worry there's nothing left to spend.
