Gateway S2000 Owners Members for St. Louis MO and area.
Led Lighting
Old Sep 23, 2008 | 04:38 PM
  #91
bradleybev's Avatar
^^ No, just pay me when I get them to you.
Old Sep 23, 2008 | 05:08 PM
  #92
rehile's Avatar
Thanks bradleybev!
Old Sep 30, 2009 | 12:22 AM
  #93
Jaeden09's Avatar
Any updates on opinions/burnouts/looks/regrets?
Looking at ordering mine today.
Old Sep 30, 2009 | 05:50 AM
  #94
ryanfeldman's Avatar
i have had mine for almost 1 1/2 yrs and havent burnt out or dimmed
Old Sep 30, 2009 | 02:37 PM
  #95
tudernos's Avatar
Yeah... I replaced the dome light, trunk, and license plate. It's been almost 1 1/2 years now and it still going strong.
Old Sep 30, 2009 | 03:04 PM
  #96
PktChge's Avatar
^^ same
Old Sep 30, 2009 | 07:44 PM
  #97
mpetus's Avatar
If another group buy is in the works; I would like to get in on it.
Graham----
FYI- The 'dimming' feature when the door in open is just more resistance in current. There are about 4 connections (plugs) between the door switch and the bulb, plus extra wire length (possibly even a smaller gauge wire used?), and then the extra factor that the door switch used to connect ground to complete the circuit is spring loaded with a rather weak spring. You can actually make it a little brighter in 'dim' mode by taking the switch apart and putting some fresh dielectric grease in it and if you get real creative, add a stronger spring, but the other said factors are still causing enough resistance to make the light dimmer when using the door switch circuit. So its not really a feature built into the car, but rather a design flaw which is often over-looked. Its present on most cars.
Old Oct 1, 2009 | 07:08 AM
  #98
8BALL's Avatar
Same here. Have not had any issues over the last 1.5 years
Old Oct 1, 2009 | 08:12 AM
  #99
Jaeden09's Avatar
I ordered Two of the 9 LED ones, and two of the Xenon bulbs. Going to test them out when I get back home, and see which I like better. I won't be home for 3-4 months though, so.....
Old Oct 2, 2009 | 06:55 AM
  #100
myslows2k's Avatar
hey guys. im about to oder some dome lights from that site.
are these the ones that will fit? 1-3/4" LONG (44MM) X 3/4" (19MM) WIDE 9 led
