Gateway S2000 Owners Members for St. Louis MO and area.
Shift Knob
Old Dec 26, 2004 | 11:12 PM
AaronS2000's Avatar
Default Shift Knob
I think I am going to purchase a shiftknob. What I would like is one lower than stock, countersunk i think its called. Any ideas on where/what to get. Also this may sound dumb but how hard is the install. How do u install?
Thanks, Aaron
Old Dec 27, 2004 | 05:14 AM
rehile's Avatar
Install should be easy. If it's like the OEM knob, you'll need a 14 mm wrench to unscrew the nut (push the boot down to see it), then unscrew the knob.
The ARC Ti shift knob appeals to me ARC Ti knob pic, but I'm not sure how much it is countersunk. See also Rick's accessories for some short-throw knobs.
Happy shopping!
Old Dec 27, 2004 | 06:05 AM
8BALL's Avatar
I currently have the Team Voodoo Shift knob from Rick's. It is countersunk and lowers the shift radius by over 1". Installation is simple, as rehile indicated above. If you decide to go with a countersunk knob, you will also need to use some lock tight to hold the knob in place.
Here is a pic for your viewing pleasure.
Old Dec 27, 2004 | 07:47 AM
AaronS2000's Avatar
What is loctite exactly? An adhesive? Dont they recommend "blue"?
Old Dec 27, 2004 | 08:55 AM
8BALL's Avatar
Yes... it is an adhesive... You will want to use blue. If you use red, you will never get the knob back off, without destroying it.. I've used blue almost 3 years ago and have not had a problem with the knob coming loose.
Old Dec 27, 2004 | 11:56 AM
AaronS2000's Avatar
so that nut u screw off, do u pull it off and then not put it back on before the voodoo knob? making it basically countersunk?
Old Dec 27, 2004 | 12:07 PM
8BALL's Avatar
Yup, you've got it! The know itself is countersunk also.
Old Dec 27, 2004 | 12:18 PM
AaronS2000's Avatar
thanks
and the adhesive is basically a glue that u put in the inside of the bottom of the knob or what?
Old Dec 27, 2004 | 12:19 PM
AaronS2000's Avatar
i think im gonna get the magnum titanium knob from voodoo. good choice?
Old Dec 27, 2004 | 12:31 PM
8BALL's Avatar
Originally Posted by AaronS2000,Dec 27 2004, 04:18 PM
thanks
It's better to put the locktite on the shifter threads than in the knob. You don't want it to drip out of the knob during application, do you?
