100 Octane Plus on Crabapple in Alphretta
Here is the link to location of each Shell Station!
http://go.vicinity.com/equiva_shell/GeoFin...mit=Submit&AIR=
I've already called #5 station at Crabapple Rd, and they don't have it (100 Octane) Plus there're in Roswell.
So, check station #2 and let me know if that's the station, guys! You can also map it and type in your address and it will show you how to get there!
May be I should change "850" to "info"?
I think it's $3.99 per gallon!
But that the guy at the AutoX said that you can mix Half 93 and half 100+ But I just thought about this, Would this mess up the ECU and the MAP sensor since the fuel is much more rich? Would the car run like crap if I just switched back to Full 93 Octane?
Why do you care about 100 octane fuel? If you don't have any detonation with 93 I don't think that 100 will do any better.
Do you believe that the ECU will automatically retard or advance your timing so that you'll get more power? I think that's call i-VTEC.
