Service Engine Light?
what can be the problem. gas cap is lock up good, there was a missing small tube that was from the intake. I dont know what esle is wrong can someone help solve this problem???
Does the light look like this? If it does, and you have replaced the rubber hose, then reset the ECU. There's a few way to do that, you can remove a certain fuse (you'd have to search for which one), disconnect the battery for 10-15 min or disconnect the negative terminal of the battery and touch the positive and reconnect it.
If it's not an engine, check your owner's manual for directions on how to reset it.
