#!@##260rd Official Hard At Work Thread#@$$&$*#
Old Jan 7, 2010 | 12:16 PM
  #1901
TepEvan's Avatar
The good news is that today is my Friday
  #1902
tacocat's Avatar
Originally Posted by speed_bump,Jan 7 2010, 04:00 PM
one little f-bomb in there so pseudo nsfw
http://www.funnyordie.com/videos/324cbe11a...rody?rel=player
http://www.funnyordie.com/videos/474402c17...lated&rel_pos=2
Olide but a goodie. The part cut off is:
Man "this is my first blind date"
Woman "Oh I do it all the time:
Old Jan 7, 2010 | 12:17 PM
  #1903
TepEvan's Avatar
The bad news is that I still have 15 mins left until I can go home
  #1904
TepEvan's Avatar
  #1905
tacocat's Avatar
Originally Posted by TepEvan,Jan 7 2010, 04:14 PM
Car batteries that die after only 3 years
MDX has the stock battery in it. It is a 2003.
Old Jan 7, 2010 | 12:20 PM
  #1906
TepEvan's Avatar
5-6 years is about the time I expect. Jamie's 06 Accord battery died the other week, but I figured it was a fluke. Well, it died again today. It's either that or a problem with her key (she had a similar problem with her RSX).
Old Jan 7, 2010 | 12:21 PM
  #1907
magikcow's Avatar
that reminds me I need to start my S and my bike this weekend.. haven't touch either since it snowed.
Old Jan 7, 2010 | 12:22 PM
  #1908
e3opian's Avatar
Originally Posted by FF2Skip,Jan 7 2010, 03:29 PM
I'm online... from home.
Thank you, Bill, for the MalwareBytes site/info. Thank you, Aaron, for helping me get online at home.
NP. Told you it would be a quick fix.
Old Jan 7, 2010 | 12:26 PM
  #1909
FallenHero's Avatar
I just replaced my battery. Also, since no one is helping with my thread in the maintenance section, can anyone here help me diagnose CEL code 1457...it's the Vapor Canister....all of my fuel lines are intact though...and yes, I always click the fuel cap atleast three times.
Old Jan 7, 2010 | 12:31 PM
  #1910
TepEvan's Avatar
I didn't see your post, but here's what I found...
Code:
I also included Honda TSB 01-011 for the EVAP Vent Shut Valve, the diagnostic should be very similar to what you would do with the stupid Honda scan tool.
Honda Service Bulletin 03-001
January 28, 2003
Applies To:
See VEHICLES AFFECTED MIL Comes On With DTC P1457: EVAP Bypass
Solenoid Valve Failure
SYMPTOM
The MIL is on, and DTC P1457 [leak detected in EVAP control system (EVAP control canister system)] is set.
PROBABLE CAUSE
The EVAP bypass solenoid valve can fail due to corrosion. The solenoid valve may get water inside. If the water contains road salt, the solenoid windings could corrode, causing the valve to fail. In a few rare instances, the corrosion could be severe enough to cause an internal short in the solenoid valve, which could damage the ECM/PCM. If this happens, both the bypass solenoid valve and the ECM/PCM would need to be replaced.
Vehicles driven in the Northeastern part of the U.S. are more likely to have this problem because of the salting of roads during the winter months. Vehicles driven where salt is not used on the roads are much less likely to have this problem.
VEHICLES AFFECTED
1998-02 Accord
1998-00 Civic
1998-01 CR-V
2000-02 Insight
1999-03 Odyssey
2003 Pilot
2000-03 S2000
CORRECTIVE ACTION
Test and, if necessary, replace the EVAP bypass solenoid valve. Replace the ECM/PCM if needed.
REPAIR PROCEDURE
1. Connect the PGM Tester to the 16P data link connector.
2. Turn the ignition switch to ON (II). Turn on the PGM Tester.
3. From the PROGRAM MENU screen, select HONDA SYSTEMS.
4. From the SYSTEM SELECT screen, select 1: PGM-FI.
5. From the TEST MODE MENU screen, select 6: INSPECTION.
6. From the INSPECTION MENU screen, select 2: EVAP TEST.
7. From the EVAP TEST MENU, select 1: SINGLE SOLENOIDS.
8. From the SINGLE SOLENOIDS MENU, activate the EVAP bypass solenoid valve. Listen for a click and feel for a light tap from the solenoid valve as you activate it.^ If you can hear the solenoid valve click or feel it tap when activated, disregard this service bulletin, and look for other possible causes.
^ If you cannot hear the solenoid valve click or feel it tap when activated, go to step 9.
9. Replace the EVAP bypass solenoid valve (see section 11 of the appropriate service manual).
10. Test the new solenoid valve with the PGM Tester.^ If you can hear the solenoid valve click or feel it tap when activated, go to step 15 or 16 as appropriate.
^ If you cannot hear the solenoid valve click or feel it tap when activated, go to step 11.
11. Check the wire harness and the connectors for damage. ^ If you find any damage, repair it, then go to step 12.
^ If you find no damage in the wire harness or connectors, go to step 13.
12. Test the solenoid valve again with the PGM Tester.^ If you can hear the solenoid valve click or feel it tap when activated, go to step 15 or 16 as appropriate.
^ If you cannot hear the solenoid valve click or feel it tap when activated, go to step 13.
13. Replace the ECM/PCM (see section 11 of the appropriate service manual).
14. Use the PGM Tester to retest the solenoid valve. ^ If you can hear the solenoid valve click or feel it tap when activated, go to step 15 or 16 as appropriate.
^ If you still cannot hear the solenoid valve click or feel it tap when activated, continue with normal troubleshooting.
15. Insight only: Disconnect the PGM Tester, and return the vehicle to your customer.
16. All other affected models: Use the PGM Tester to run the EVAP system function test (see S/B 02-007, EVAP System Function Testing and Diagnostics With the PGM Tester).^ If the EVAP system passes the function test, disconnect the PGM Tester, and return the vehicle to your customer.
^ If the EVAP system fails the function test, continue with normal troubleshooting.
Honda Service Bulletin 01-011:
http://i281.photobucket.com/albums/k...rd/P1457-1.jpg
http://i281.photobucket.com/albums/k...rd/P1457-2.jpg
