Original Gangsters Thread!
Old Sep 29, 2006 | 11:40 AM
  #1861
TepEvan's Avatar
Originally Posted by Black Nugget,Sep 29 2006, 03:38 PM
I should be able to get you a better price for a local dealer though, just let me know.
I might do that... but it's not high on my want/need list.
  #1862
TepEvan's Avatar
Thanks for your help though
Old Sep 29, 2006 | 11:43 AM
  #1863
Black Nugget's Avatar
Anytime bud! By the way, that o2 sensor I gave you is set up to run a test pipe. It has the mechanical o2 sensor cel trick already on it!
When you install it - put it in the test pipe first, then plug it in. That way the line doesn't get all twisted.
Old Sep 29, 2006 | 11:46 AM
  #1864
TepEvan's Avatar
No test pipe here...
although I have a question about that (more directed to any MD'ers in the o.g. hizouse). If I am running a test pipe with a fouler, that would show normal levels to the ECU right? So when I went to vehicle emissions, it would come up as normal readout?
Old Sep 29, 2006 | 11:58 AM
  #1865
Poindexter's Avatar
If your check engine light isn't on, your ECU is reading things as normal.
Old Sep 29, 2006 | 12:00 PM
  #1866
TepEvan's Avatar
That's what I was thinking, thanks for the confirmation though.
Old Sep 29, 2006 | 12:07 PM
  #1867
As I have never had any type of emissions testing I am not too sure exactly how they work. However, if it is the way that I have been told where they connect to your ECU - you should be fine! The Spark Plug Fouler trick is designed to pull the o2 sensor away from the exhaust flow causing it to give a normal reading!
Old Sep 29, 2006 | 01:40 PM
  #1868
TepEvan's Avatar
Yup, that's how they do it. I got it done about 4 years ago or whatever and then about two years ago they tried to and failed me because the car was too low, but they gave me a two year extension. 1/07
Old Sep 29, 2006 | 01:43 PM
  #1869
Just wondering... what would happen if you change the car back to stock, get it to pass emissions and then put your aftermarket parts back on the car?
That is what a lot of locals in this area do for state inspections.
Old Sep 29, 2006 | 01:56 PM
  #1870
TepEvan's Avatar
My problem wasn't with the test itself, but with the height of my car. They say I wouldn't be able to make it over the dyno rollers to the other side where the ECU OBDII is. No biggie to me
