Hawaii S2000 Owners S2000 Owners in Paradise Hawaii Owners
Clutch Fluid bleeding..
Old Sep 8, 2008 | 11:50 PM
ahrmike's Avatar
Default Clutch Fluid bleeding..
Jeezus, thanks for pointing out my dirty clutch fluid Collen(sp?)...I was wondering why I couldnt ever get the balance right..I was like wtf? I drove stick for the last 6 years, why the hell am I close to stalling/chirping/all manners of bad stick driving when I drive this car?!
Turns out my clutch fluid was BLACK.
check it out:
Thats everything I bled..! The fluid was so dirty you cant even see through it! The slave cylinder would sometimes stick and not 'let go' for a while so thats why I got so close to stalling all the time.. (i think??)
Took it out for a spin right after the bleeding/flushing.. HOLY SH*T night and DAY. The car feels so much better/shifts better I can actually rev-match now..
ok. that is all...for all you 01- owners...might wanna check your clutch fluid too.
Old Sep 9, 2008 | 12:15 AM
1001K's Avatar
Yeah...the clutch fluid doesn't stay clean long either. I try to replace the clutch fluid every 6 months.
Old Sep 9, 2008 | 12:47 AM
ahrmike's Avatar
ohh... I swear it was cleaner when I bought the car..but I guess it was that it was sitting for a while...so when I bought it and started DDing it, it just cleaned the inside of all the sludge....? idk!
Old Sep 9, 2008 | 08:43 AM
kent-k's Avatar
mine was just as black and still works fine. is your clutch still sticky? lots of times it's actually the clutch slave actuating rod that's worn. it wears to the shape of the clutch fork and needs to be cleaned and polished.
Betty's car was doing the same, getting stuck at the end of the pedal stroke and not coming back up quickly. i pulled the rod. sanded it smooth and it's been great for the last 20K
Old Sep 9, 2008 | 11:49 AM
alphaproject's Avatar
yeah mine sticks a little at the bottom when its against the floor
Old Sep 9, 2008 | 11:53 AM
kent-k's Avatar
https://www.s2ki.com/forums/index.php?showtopic=370792
Old Sep 9, 2008 | 02:07 PM
ahrmike's Avatar
Ah...that might be a problem too, when my dad was pumping the clutch he said it would go to the floor and get stuck too. Mebb thats whats going on...
The clutch deff feels waay better...I actually have control of the clutch now...
Cool, I should probably do the shaving of nipples
How do I get it that polished? buffer?
Old Sep 9, 2008 | 04:43 PM
jzz30's Avatar
the fluid does make a difference though.
Old Sep 9, 2008 | 06:25 PM
istdercollen's Avatar
Originally Posted by ikeyballz,Sep 8 2008, 09:50 PM
that is some dirty fluid.. looks worse than when I checked it the other day! Well that's just another thing you can check off the list. I know you said the car has to last you for a while so we'll do what we ccan to help ya out!
Old Sep 10, 2008 | 05:18 PM
ahrmike's Avatar
haha yeah, three things left before I can relax.
trans fluid, diff fluid and crack open the valve covers to check to see if no valves are dropping.
thanks man!
after that i can finally start working on everything else..
