Hawaii S2000 Owners S2000 Owners in Paradise Hawaii Owners
clutch help!
Old Oct 18, 2010 | 09:38 PM
DTAG's Avatar
call me if u need help.....429-4038
Old Oct 18, 2010 | 10:50 PM
bouford's Avatar
Originally Posted by moon knight,Oct 18 2010, 07:05 PM
this weekend, clutch developed lots of play and did not shift unless clutch was at the floor.
just bled my clutch now its stuck at the bottom. guess its time to replace the master cylinder and might as well change the slave too. anything i should know before i do this on my own such as misc parts i should buy? any extra hoses or connections or o rings?
found this thread. hope it helps. gl! https://www.s2ki.com/forums/index.php?showt...&#entry17050198
might as well do this mod too : https://www.s2ki.com/forums/index.php?showtopic=370792
Old Oct 21, 2010 | 08:44 PM
moon knight's Avatar
will definitely let you know when i need the help D
Thanks felipe for the sites.
I bought the parts at honda windward and it will come in on friday. gonna have it done by sat if all goes well.
Old Oct 22, 2010 | 10:00 AM
rossco's Avatar
Originally Posted by jzz30,Nov 14 2009, 11:51 PM
might as well change the line too!
why would you replace the line unless it cracking or leaking. or upgrading to a steel braided line? this makes no sense. in that case, you should replace all your rubber brake lines also. i would just change the master cylinder, and the slave only if it is leaking. no point in wasting money to change a part that is still good.
Old Oct 28, 2010 | 11:37 PM
replaced it last weekend in time to test it at the track. ran into some trouble sitting the ball into the cup. They didnt align and i made a big mess, got some cuts because of all the sharp metal behind the clutch pedal. it all works fine now. i just gotta adjust the pedal to the right setting. Just gonna monitor the reservoir and make sure the levels dont change.
Old Oct 29, 2010 | 10:41 AM
jzz30's Avatar
thats just how i am i guess... the line is like 20~30 bucks so might as well change it. my theory on clutch hydraulics is if one thing goes out such as your master, the rubber had deteriorated and all the particles ar just stuck in there tearing at all the other seals. so might as well change out the slave. and since you are taking everything off anyway just change the line. then you wont have to worry about it for the next i dunno 5-10 years?
sounds better to me than having to work on the car again for a similar problem, and risk damaging a new part you put in. plus all new parts is the best thing in the world
Old Oct 29, 2010 | 05:39 PM
JustinsanE's Avatar
Originally Posted by bouford,Oct 18 2010, 08:50 PM
I am about to do that second mod this weekend due to squeaky and rough clutch travel.....
laserred02
Nov 28, 2012 07:12 PM
sevenoneduy
Mar 29, 2010 07:10 PM
epaplia
Oct 20, 2008 10:16 AM
bunz559
Sep 26, 2007 11:14 PM
SilverstoneS2k_FL
Jan 12, 2005 08:18 AM
