Clutch Pedal Feeling Weird Lately (2nd try)
Since you've already checked the fluid and checked the clutch adjustment, it might be one of a couple of things.
If it's under warranty, take it to a dealer you know who does good work.
- Air in your clutch fluid line. (You may have to bleed the system.)
- Faulty clutch master cylinder. (Replace)
- Faulty clutch slave cylinder. (Replace)
- One of your clutch disc springs may be getting stuck. (Replace)
Mine has has actually been doing the exact same thing for about two weeks. I dropped it off at the dealer yesterday so they could take a look at it. I called for an update when I read this and my service advisor said they are going to have to pull the tranny and he will call me as soon as they get a diagnosis. I will let you know what I hear. Have you had the TSB done for the clutch ringing yet? I had mine done about 8 thousand miles ago and I think that is the problem. How many miles do you have?
Mike, I'm not getting the pulsar action and the other strange thing is I can't hear the throw-out bearing at all. Most cars I've had, I can hear the throw-out bearing if I listen for it (when nothings wrong).
Maybe the pull type PP setup leave bearing engaged at all times.
tick.....tick....tick........is right
[Edited by RT on 06-07-2001 at 06:47 PM]
I got my car back Friday afternoon. The dealer found a "weak" pressure plate whatever that means. Under warranty they replaced the flywheel, pressure plate, and throwout bearing.
I hope this helps.
I hope this helps.
