View Poll Results: When I checked my sparkplugs...
They were loose!
21.21%
They were properly tight.
78.03%
They were way too tight!
0.76%
Voters: 132. You may not vote on this poll
Old Oct 1, 2001 | 05:10 PM
jschmidt's Avatar
Default When I checked my sparkplugs...
Post the results of your sparkplug check in this poll.
Old Oct 1, 2001 | 05:38 PM
RandyP's Avatar
I may have got some movement on the torque wrench, but they were tight enough to seal properly. Hex bolts were torqued higher than the spark plugs.
Old Oct 1, 2001 | 06:22 PM
DaveA's Avatar
Perhaps the more important thing is to get the VINs of the cars that had loose plugs. Maybe the problem is only on a narrow range of serial numbers.
#1924 had plugs installed correctly.
Old Oct 1, 2001 | 07:47 PM
Mindcore's Avatar
I can't vote, but my front 2 plugs were finger tight
Vin # 602
Old Oct 1, 2001 | 09:33 PM
calc's Avatar
When I replaced my stock plugs with Densos, the stock plugs seemed to be torqued well--they weren't easy to break loose, although I didn't actually check the torque.
You bet I used a torque wrench and tightened the Densos down to spec.
cal
Old Oct 2, 2001 | 03:45 AM
CoralDoc's Avatar
I just voted, but to clarify, #2 was loose (finger tight) and the rest were properly tightened.
Old Oct 2, 2001 | 05:42 AM
tpn's Avatar
tpn
I also changed to Denso a few months back.......#2 and #3 were under torqued but were not that loose....... "00/8821
Old Oct 2, 2001 | 08:53 AM
gregstevens's Avatar
Banned
I would have tested mine, but it had fallen completely out!
Seriously, interesting poll...as I said before, I can't explain for certain what happened during that whole mess, but I 100% believe that it all started with the spark plug. I'll be posting pics later on today...
BTW, I should be picking up my car this weekend.
Old Oct 2, 2001 | 01:32 PM
Luis's Avatar
FWIW, I was at the dealer yesterday, and asked him to verify the spark plugs. He said "whatfor?". He basically told me he has never seen a loose spark plug in his professional life except as the result of amateur tampering... and certainly not in an S2000.
When I asked him about Hugo (a fellow member) that had a case of the "loosies" , he said that someone had been playing around with the plugs.
Don't know what Hugo thinks about this, but the fact that he has a Spoon carbon head cover might have something to do with it. (Hey, hugo, did you or did you not touch the plugs? ).
Old Oct 2, 2001 | 03:53 PM
Rick Hesel's Avatar
I changed to the Denso Irridiums about two months ago and the stock plugs were all torqued to spec. I noticed that the manual recommends "anti-seize" compound on the plug threads and I wonder if the factory uses this stuff and whether it might be responsible for some plugs coming loose.
