Preparing for track day?
Old May 3, 2007 | 11:41 PM
J's_Racer's Avatar
Default Preparing for track day?
i just put in new oil filter , new oil , new plug , new tranny and diff fluid
do i need to run water wetter and flush out my coolants?
and do i have to use an aftermarket cooling plate?
thanks a lot guys
Old May 4, 2007 | 12:07 AM
3vilmonkey!'s Avatar
I think all you have done would be fine but the other things would just make things better
Old May 4, 2007 | 12:26 AM
mikegarrison's Avatar
Dude, unless you are behind on your maintenance, basically all you have to do is clean the car out and show up.
After your first track day or two, you will start to find that your OEM brake pads are no longer suitable. At that point, you will want to buy some track pads. Assuming this is a daily driver, you will them want to learn how to swap your track brake pads with your street brake pads.
Next on the list will be replacing the brake fluid with DOT4 fluid like Motul 600 or ATE 200/Superblue.
After that, come back and ask the question again.
But the stock coolant and fluids and the like are just fine for the track.
Old May 4, 2007 | 05:46 AM
8kGoodENuff's Avatar
At what mileage was the first time you guys changed out the tranny and diff fluid?
I just started really getting into Auto-Xing this year and I want to make sure I keep the car maintained nicely. Right now I have 16000 miles on the car without any fluid changes other than the motor oil roughly every 4000 miles.
Am I up for tranny and diff fluid changes or could I continue on with how it is now?
Andre
Old May 4, 2007 | 07:31 AM
Iceman1's Avatar
Andre
my car was purchased used... so i changed everything after i bought it...
i'd do the diff fluid now... use LE-607...
depending on how much you auto-x... you can probably stick to the "severe usage" schedule on the owner's manual for the tranny... regular auto-x'ers should chime in soon...
Old May 4, 2007 | 08:05 AM
GT Motoring's Avatar
scared me for a sec... lol I was like when the hell did i post this, and why? lol
But to answer your questions.I would for sure do a high temp brake fluid before going on ANY track. Valvoline Syntech is pretty readily available at any autozone etc, and will work well for your purposes. If you can afford to, id do upgraded pads also check your rotors for any flaws or cracks etc.
Old May 4, 2007 | 09:00 AM
crash's Avatar
I think the second j's should change his name.
on the track ready things and fluids.
changing the diff and trans fluid can't hurt.
I would assume on your 1st few track days you are not going to be pushing the car to its limits so it could be fine.
you may boil the brake fluid
Old May 4, 2007 | 09:18 AM
l8brakr's Avatar
It should be changed for him. It's ridiculous not even considering that the other is a vendor which could really pose some problems.
Old May 4, 2007 | 09:27 AM
crash's Avatar
the guy thats been a member for 37 days needs to be changed.
I am sure a mod could jump in and save the day
sorry 37 day old J's Racing guy but its already taken
Old May 4, 2007 | 10:58 AM
Iceman1's Avatar
what kind of freakin attitude is that?
