My FULL RACE Turbo Kit came in! *PICS*
Old Sep 9, 2006 | 10:12 AM
foxer10's Avatar
Default My FULL RACE Turbo Kit came in! *PICS*
Well its here, 2 months later and its going to be worth it. Everthing in the kit is top quality. Clean welds. HPC coated from turbine to downpipe, this thing will spool quick as hell which is what i was looking for. Not much time to work on it but we might get it all running by end of the year. Special thanks to Anthony & Todd @ Full Race, and Nippon Power.
Manifold, HPC coated
Extremely clean welds, all smooth inside
Downpipe section 1 - HPC Coated
Downpipe section 2 - HPC Coated
GT3037R .63
Turbine housing - HPC Coated
Old Sep 9, 2006 | 10:20 AM
passmans2kny's Avatar
this just made me so happy, mine will be here in a month, i talked to full race last week and they said they arent doing the hpc coatings anymore, anyway everything looks amazing i love the turbo inlet
Old Sep 9, 2006 | 10:22 AM
Black Nugget's Avatar
- Very nice!
What are the motor specs? Stock motor, stock compression, stock head gasket?!? Details!!!!
Old Sep 9, 2006 | 12:00 PM
foxer10's Avatar
passmans2kny, I knew you'd like it If they arent sending it out for coating, you can do it yourself when it comes in. SHip the parts out to HPC and let them do it. I highly recommend spending extra to coat it. The finish will be consistent and heat will be reduced.
Black, Im planning to keep it stock block for now with following below:
ACT HDSS Clutch
AEM EMS w/ UEGO
ARP Head Studs
Cometic 2mm HG
My goal is extremely quick spool up with around 400whp. Guys next door just got a dyno. Ill be able to do a baseline run and compare.....muhahaha
Old Sep 9, 2006 | 12:27 PM
c_me_go's Avatar
sounds great Foxer...
I just started a build myself... A full motor build and with a Love Fab kit.. Also doing my Rear Diff and a Ricks 4.57 Final gear.. plus tons more...
Old Sep 9, 2006 | 01:18 PM
ACT HDSS Clutch
AEM EMS w/ UEGO
ARP Head Studs
Cometic 2mm HG
I'm eager to see what kind of numbers you are able to make in the end!
Do you have a set target psi or are you just going to adjust the psi to meet your 400whp goal? Do you have a tuner in mind - in the Florida area I keep hearing a bit about a guy by the name of Mace in the Jacksonville area. From what I've read, he has some experience with stock S2000 motor pushing over 500whp, but then again reliability does have a huge factor in there.
Old Sep 9, 2006 | 01:24 PM
XclusiveAutosports's Avatar
Congrats on the kit. Are you installing it yourself? If so, good luck with it.
If you plan on going with a built motor, the gears might hurt you more then they will help depending upon how much power you put down.
Old Sep 9, 2006 | 01:27 PM
ACT HDSS Clutch
AEM EMS w/ UEGO
ARP Head Studs
Cometic 2mm HG
you just described my set up as well, i just ordered my arp studs and 2mm cometic head gasket a few days ago, now for the dam expensive aem ems, i really wish it was cheaper
Old Sep 9, 2006 | 01:43 PM
A few local guys have had problems with getting the thicker cometic gasket to seal with the ARP headstuds, but had no problems with the stock head studs. Just something to think about.
