Hon-aux For My04?
Old Jul 22, 2004 | 10:50 AM
Slac11's Avatar
Default Hon-aux For My04?
My previous car was a 01 Prelude which I had the HON-AUX connected to the AUX of the stock head unit for my iPod. I bought the HON-AUX from http://www.installer.com/aux/. I called them to order another for my 2004 S2k and they said that the head unit in the 04 has a diffrent headunit and there is no connector that I can use through the AUX port.
Does anyone know if there is a connector that fits into the AUX port on the stock headunit so I can use my iPod.
Thanks
Old Jul 22, 2004 | 12:16 PM
Scanman's Avatar
I just got this one for my 04. Works great!
http://store.yahoo.com/logjam/piehon03pcson.html
Old Jul 23, 2004 | 06:26 AM
00CivicSi's Avatar
Scanman,
Can you use that device in addition to the factory CD changer? For example, so that I could have the option of using the iPod or the CD changer without unplugging and plugging.
Thanks in advance on any further input...
Old Jul 23, 2004 | 07:13 AM
Bass's Avatar
I am pretty sure you would need a Y conector if you don't have the factory 04 factory CD changer??
if you have the changer there should be a pigtail that would attach to the factory XM - if you don't have XM you could plug the pie adaptor into the X/M open pigtail
Old Jul 23, 2004 | 01:13 PM
Scanman's Avatar
I don't have the stock cd changer so I just plugged the PIE-AUX directly into the head unit. I did check the pre-wired connector in the trunk for the CD changer/XM too, but the gender was the same as the PIE-AUX so I couldn't connected it there. There's a bus cable that comes with the CD changer kit which splits the connection in the trunk, but I think the gender would be wrong too. According to the comments on logjam, you probably can't use PIE-AUX with the cd-changer or XM, but I'm not certain.
IMPORTANT APPLICATION NOTES: The HON03/PC-SON works with non-navigation-equipped 2003-2004 Honda Accord, Element and S2000 with or without the 6 disc in-dash CD changer and will also work with the factory MP3 player too. If you have factory XM, you MUST disconnect it in order to use this interface.
integlspwr
Jul 28, 2008 09:58 AM
ketjlh102
Dec 29, 2005 09:05 AM
Kiteland
Jan 16, 2005 09:38 AM
snowball
Jan 12, 2004 07:30 AM
2Scars
Sep 13, 2002 07:18 PM
