Brake Fluid Selection for Street/Track/Auto-x
Having my name slandered online is not acceptable, so here is the information AGAIN:
ARRANGED BY DRY BOILING POINT:
DRY:401F -- WET:284F --- DOT3
DRY:446F -- WET:311F --- DOT4
DRY:502F -- WET:343F --- VALVOLINE SYNPOWER
DRY:509F -- WET:365F --- MOTUL 5.1
DRY:527F -- WET:302F --- AP RACING 551
DRY:536F -- WET:392F --- ATE SUPERBLUE/TYP200
DRY:590F -- WET:410F --- AP RACING 600
DRY:590F -- WET:518F --- CASTROL SRF
DRY:593F -- WET:420F --- MOTUL RBF600
DRY:610F -- WET:421F --- NEO-SYNTHETIC SUPER DOT 610
ARRANGED BY WET BOILING POINT:
Thanks for the handy list.. the only other data needed (besides approximate price) is to know how rapidly they absorb water.. what is the boiling point 60 days after a flush? As I understand it, the number will vary quite a bit and that is the reason some of the high BP formulations are not recommended for street use.
Originally posted by krazik
You'ld almost never need to change it
I found these fluid tips while looking for an answer...
THINGS TO REMEMBER
Brake fluids dry boiling point is more important then wet boiling point when used in a racing brake system.
Passenger cars very rarely will undergo a brake fluid change making the wet boiling point more important.
Racing brake system fluid is changed often and a system with fresh fluid will most likely not contain water.
Because of this, racers should be concerned with the dry boiling point.
Racing fluid exceeds DOT 3, 4, and 5.1 dry boiling point specifications.
Never use silicone based fluids in racing brake systems.
Using racing brake fluid will increase performance of the braking system.
Never reuse fluid.
Originally posted by statueman
Sooooo....If I use my car mainly for the street but also auto-x say twice a month and I don't want to change the fluid all the time, what should I use?
Great info here.
I've never seen an actual rating or quantitative analysis of different brake fluid brands moisture absorption rates...
Anecdotally, I've heard that Ate (my current choice) absorbs water slowly and that Castrol SRF absorbs it pretty quickly. I don't know about Motul, which would be my second choice if Ate was unavailable.
For my motorcycles and utility vehicles, I use Castrol LMA, which does not have the high boiling point of the racing fluids, but still higher than most stock fluids. LMA stands for Low Moisture Absorption, so change intervals can be longer.
As a sidenote, I've heard that Ford Heavy Duty has a very high dry boiling point, and is very inexpensive. A good choice for a racecar or other vehicle that has it's fluid purged frequently but sees high heat levels in the brake fluid...
