Comptech SC spark plugs and belt
I am starting to replace some wear items on the S. What plugs do you guys recommend for a Comptech SC w/o AC? I have been searching around it seems like alot people are using IK24s. Does the the SC benifit from colder then stock plugs and what about gap? What do most of you guys run? I have the stock pully and management as well.
Also how often are you supposed to change the SC belt? and do they normally show any signs of wear before they go?
Thanks
Thanks
The belt should be checked periodically for signs of wear. You will see cracking where there aren't any original built in cracks for flex. You will also see fraying and delamination. My original Vortech belt has now been on for over 15,000 miles and it still looks OK. It all depends on how it's been adjusted.
Originally Posted by Dsgs2k3,Apr 3 2006, 06:17 PM
will bosch platinum 4 tip spark plugs work for a supercharged S
