Which nut s the Spindle nut
Old Sep 20, 2004 | 04:06 AM
beroznikmal's Avatar
Default Which nut s the Spindle nut
Hi guys,
The clicking is making me crazy and I need to address this issue NOW..... Do you guys have a picture/diagram of the spindle nut????? I tried looking in the manual but had no luck.....
Yogi, if you have one a special diagram, that would be super...
Thanks
Beroz
Old Sep 20, 2004 | 04:38 AM
xviper's Avatar
It's that giant nut in the middle of the brake rotor.
Old Sep 20, 2004 | 06:16 AM
afetsman's Avatar
And if you do it the nut is a 36mm...as the manual states the incorrect size.
Old Sep 20, 2004 | 06:38 AM
thank you sirs
Old Sep 21, 2004 | 11:19 AM
And I am supposed to torque this baby to 181 lbs.ft???????????
Old Sep 21, 2004 | 11:47 AM
alexf20c's Avatar
I always just tighten that sucker on there as tight as I can with a 1/2dr breaker bar, and another breaker on top of that, then back it off an 1/8th of a turn.
Old Sep 21, 2004 | 11:49 AM
alexf20c's Avatar
So you don't use jackstands either, Dave?
Old Sep 21, 2004 | 12:27 PM
xviper's Avatar
The TSB for this by Honda has a revised torque of 220.
Old Sep 21, 2004 | 12:28 PM
xviper's Avatar
This was the common method when doing the rear wheel bearings on a FWD car. I'm not so sure this is applicable in the S2000.
Old Sep 21, 2004 | 12:29 PM
xviper's Avatar
I was changing my snow tires. If I ever put any part of my body under the car where I could get pinned to the floor, you can bet your sweet bippy there'll be a jackstand under there.
