Looking for springs with a 2 inch drop
Old Mar 27, 2001 | 02:43 PM
Brian Peak's Avatar
I want a spring with a 2 inch drop. Know of anyone? And I don't want to wait a month to get them. Any help would be greatly appretiated.
Old Mar 27, 2001 | 03:27 PM
cthree's Avatar
Administrator
2"????
I'm down an inch and have lost a lot of adjustability in the rear camber. You'll need a camber kit too unless you like riding on the inside of your tires that is. Comptech coilovers will give you 3" if you want them but even with two you'll rip your mufflers off on the first speed bump you hit, that is if you make it over at all.
Old Mar 27, 2001 | 03:36 PM
Brian Peak's Avatar
Thanks, I guess I should stick with an inch or so.
Old Mar 27, 2001 | 04:43 PM
nwk00's Avatar
Originally posted by cthree
2"????
Are you sure you that will happen? Our car is not that low to begin with right?
Old Mar 27, 2001 | 05:16 PM
Scot's Avatar
i dropped about 1.25" and my car now bumps and scraps
on all kinds of crap. LOW-S2000 (MARTY - who has abandoned our little board it seems) has the comptech coilovers and was dragging on gum wrappers at Carlisle last year.
Scot
Old Mar 27, 2001 | 06:25 PM
cthree's Avatar
Administrator
at one inch I scrape the front lip at least twice a day and got hung up on a speed bump at the DMV *crunch*. Not a happy sound. I've dinged the mufflers twice. Once when I first lowered it on TFota's driveway and once today. The undercarriage is a lot lower than you think. It's the wheel wells that decieve the eye.
Old Mar 27, 2001 | 11:49 PM
mingster's Avatar
kg/mm DR21 Racing springs are pretty cool.
Old Mar 28, 2001 | 12:00 AM
lvs2k's Avatar
Why not just leave it stock?
Old Mar 28, 2001 | 05:29 AM
CHOWBOX's Avatar
I just dropped mine 1
Old Mar 28, 2001 | 05:45 AM
shaner's Avatar
Won't an alignment fix the rear camber problem?
Also, what kind of springs should I get the keep the car from bottoming out on hard bumps? I have the Comptech springs and have lowered only an 1" or so... How can you visually see negative camber?
