they have an LED undercar kit now... im getting one for my S, uses a fraction of the power of the standard tube kits, twice as bright, changes colors, lots more... under car kits looks amazing on the S by the way... if u want more info pm me or 1badride
It works well, very bright, and if installed correctly (it's fairly easy), it lasts a long time. You *will* need to remove the tubes before snowy weather - the tubes will not hold up.
As well, do not run the neons with the car at idle, you will burn out the regulator inside the alternator over time (1-2 months).
The LED systems out there are OK, but not as bright, and the light pattern is quite different than neon (less diffused).
If you know of any LED kits out there that are 2x brighter than NEON, PM me, I'll order one and install it and let you know how it goes...
