Using jack stands
Old May 24, 2003 | 02:31 AM
Boit's Avatar
Default Using jack stands
I want to put my S on jack stands to change the oil and filter for the first time and am uneasy about how to initially get it jacked up with a floor jack. I was just in the garage looking underneath the front to see where I could position the floor jack but am not quite sure. There is a steel cover in the center of the front frame rail that looks like it might be a good site to lift with the floor jack. Any advice? I don't want to damage my new car, ya know.
Old May 24, 2003 | 03:02 AM
Stanley's Avatar
Here you are.......A nice detailed thread on jack points.....happy servicing....
https://www.s2ki.com/forums/showthread.php?...threadid=115705
Old May 24, 2003 | 03:20 AM
ralper's Avatar
You might have some difficulty getting your floor jack under the car. To remedy this I constructed, out of 2x10s some ramps.
You buy a 2x10x10' and have it cut into 2 2' sections and 2 3' sections. Bevel the leading edges with a belt sander (or very carefully a radial arm saw set to bevel) and place a 2 foot section on a 3 foot section. Glue and screw them together.
You will need 4 to lift the entire car. You can only go 2 planks high as three won't fit under the body.
To change your oil, you don't need jack stands, just 4 of these ramps to drive onto. You might want to install a Fumoto Oil Valve
With this you can do your oil changes from above, without raising the car. Go to www.fumotovalve.com for info on the valve and do a search of this board for threads about it.
Finally, this is what an S looks like on jack stands. I did this to paint the calipers.
Good luck.
Old May 24, 2003 | 01:47 PM
ralper's Avatar
I had originally posted an incorrect link to Fumoto. Thanks to tritium_pie I have now edited the previous post with the correct link. It is
www.fumotovalve.com
Old May 24, 2003 | 03:57 PM
Boit's Avatar
I deeply appreciate the advice and link to another thread that had excellent pics. It really makes things much easier knowing that I can change the oil without lifting the car. I'm defintely going to order the Fumoto valve as I have one on my pickup truck.
Old May 24, 2003 | 04:08 PM
ralper's Avatar
Make sure that you order the adaptor as well. It will not fit without the adaptor.
Old May 24, 2003 | 04:16 PM
Boit's Avatar
Ralper: I just ordered the valve AND the adaptor. Thanks again.
Old May 24, 2003 | 04:32 PM
Gforce's Avatar
Thank you, I appreciate the info
Old May 24, 2003 | 04:44 PM
Crabby Guy's Avatar
If you get this with the nipple, is there something that will attach there to drain the used oil into?
Old May 24, 2003 | 04:50 PM
ralper's Avatar
You have to get a piece of tubing to slide over the nipple. As you can see from my photo, I have the nipple, but I just slide a "low profile" drain pan under the car and let it fill.
I intend to get a Rick's (formally DiGrappa) cross brace soon. I don't know if the oil will get on it. If that happens I'll get and use some tubing. I think the tubing is relatively cheap and available at most "homeowners" stores like Home Depot.
markpenske
Jul 10, 2012 08:22 AM
Carbon Blue
Jul 20, 2010 11:50 PM
jay r
Jul 16, 2004 05:29 AM
tram57
May 22, 2001 03:35 AM
