paint/stone chip
Old Jun 23, 2003 | 09:25 AM
cherick's Avatar
Default paint/stone chip
Any help would be appreciated for your recommendations on reparing small 1/16 inch paint chip.
Thanks
Old Jun 23, 2003 | 09:30 AM
dangarza's Avatar
DO NOT use the brush that comes with the OEM touch up paint (Too broad) is better to use a toothpick and just dab it. Take your time...
Buy a bra.
Daniel
Old Jun 23, 2003 | 09:52 AM
silverstone2003's Avatar
i actually had really good luck with a very sharp pencil tip, trust me dangarza is right TAKE YOUR TIME, i know you want to hide the chip asap, but if you try to do it in one coat it will drip and lookl ike crap, use very light coats and wait about 2 hour between every light coat,
Old Jun 23, 2003 | 10:51 AM
Albert's Avatar
You can also mix in a little bit of enamel reducer to make thinner coats.
Old Jun 23, 2003 | 12:56 PM
JL9000's Avatar
First peel off any loose paint around the chip and lightly sand the chipped place, then clean the area with dish detergent or Simple Green.
Let the chip dry overnight, then start applying thin layers of touch-up paint. Let each coat dry for around 30 minutes or so until the touch-up bulges higher than the rest of the paint. Let the paint cure overnight, then sand down the area with a 1500 grit sanding block. Always have enough lubrication for this. Afterwards, use a compound or strong polish and give the chipped area a good rub, then use a light polish to remove swirl marks, then finish off with some wax.
Good luck.
Old Jun 23, 2003 | 02:37 PM
jeffbrig's Avatar
I prefer 2000 grit to 1500 (leaves finer scratches) to sand it flat, then 3M swirl mark reducer to buff out the micro scratches.
Old Jun 23, 2003 | 02:39 PM
jeffbrig's Avatar
BTW, not sure what color you have, but I've found that Honda's red touch-up paint leaves a lot to be desired in the color matching department. I've heard good things about the AutoSharp? pens that were recently promoted here on s2ki.
Old Jun 23, 2003 | 02:57 PM
done0908's Avatar
If you get silverstone, I suggest you just forget to paint now and wait until more chips then repaint the whole bumper. You almost impossible to match the factory color either from OEM touch up paint or autosharp. Because I have the same problem. It comes out two different colors (you can see it under the sunlight) on my bump now.
Old Jun 23, 2003 | 04:10 PM
JL9000's Avatar
[QUOTE]Originally posted by jeffbrig
[B]BTW, not sure what color you have, but I've found that Honda's red touch-up paint leaves a lot to be desired in the color matching department.
dfvs2k
Jul 28, 2010 03:38 PM
kent-k
Sep 21, 2006 12:25 PM
Surreal_S2K
Nov 18, 2005 04:48 PM
03s2kman
Nov 20, 2003 09:05 AM
Bruinlax
Nov 5, 2001 11:23 AM
