Comptech's Aftercooled Supercharger INSTALLED!
This kit uses the same pulley as the standard kit--if they change the pulley and up the boost then they have to get carb-certification all over again. The nice thing is, though, that I should be able to up the boost 1-2 psi while still keeping the intake temps low! More horsepower can be had without much effort. But right now I'm not exactly in need of more horsepower.
I'm not sure how much the install of everything cost--because 1) I'm afraid to look at my invoice and 2) because I did the oil-jet update and had the flywheel, PP, Clutch and the rear differential strengthened all at the same time and haven't broke all costs out.
The Aftercooler unit itself (Retail) is ~$1250.
That's a familiar looking setup
When you're ready for more power, I suggest the 785cc injectors, AEM, and 11 psi pulley. SOMEDAY I will be able to actually get the damn dyno sheets from the dyno and post them. I think I mentioned before it put down 355 to the wheels without pinging on 94 octane.
