Resetting Ecu
Old Oct 8, 2003 | 04:26 PM
Cole_19's Avatar
Default Resetting Ecu
I need instructions on how to reset the ECU! Already did a search and couldn't find anything!!!!!
Old Oct 8, 2003 | 05:00 PM
Euclid's Avatar
step 1 - disconnect the negative battery terminal
step 2- go get a beer and wait 15-20 minutes
step 3- reconnect the negative battery terminal
Old Oct 8, 2003 | 06:11 PM
CutieBonny's Avatar
Banned
There's an easier way to do so. Remove a fuse from the box under the driver's dash. Which fuse? Do another search and you'll find it. I don't remember which one at the moment, so I can't say.
Old Oct 8, 2003 | 11:07 PM
3ngin33r1's Avatar
#25, 7.5A
Old Oct 8, 2003 | 11:38 PM
S-ToDo's Avatar
why ECU need to be reset?
Old Oct 9, 2003 | 04:52 AM
cdelena's Avatar
Although it will turn off the check engine light (just temporarily if conditions are not changed) it forces the ecu to relearn all fuel trim. I will not do it as it screws with the idle and low speed response. I use an OBD tool to reset CEL conditions, instead of living with idle problem for the next twenty trips.
Old Oct 10, 2003 | 04:12 PM
epnfrn's Avatar
3ngin -
are you sure about that? just checked my car ... don't have a #25 ... do you mean #16 (7.5A) "Back-up"
b
Old Oct 10, 2003 | 06:59 PM
Incubus's Avatar
Second fuse from top on right(Third Slot). I believe it IS marked back-up.
Old Oct 10, 2003 | 08:11 PM
3ngin33r1's Avatar
Hmmm, my ESM numbers them different than the user manual. Odd, I'll look into it but yes, the backup 7.5A.
Old Oct 10, 2003 | 09:09 PM
fly_S2K's Avatar
Resetting ECU:
1. Remove the third fuse down from the second column (No. 25 Backup 7.5 A Fuse)
2. Wait for 60 secs and replace the fuse (make sure to note the orientation)
3. Turn on the car (with all electrical items turned off & throttle fully closed) and let it idle for 5-6mins (Idle learn process)
