How about this tool for valve adjustments?
Old Jan 1, 2004 | 10:16 AM
Road Rage's Avatar
Default How about this tool for valve adjustments?
http://www.aep.bigstep.com/clik.htm
Old Jan 1, 2004 | 10:31 AM
fly_S2K's Avatar
Have you used this before RR? Any comments?
Old Jan 1, 2004 | 11:46 AM
Prolene's Avatar
It's quite a good idea. Beats the constant go/no go method of the feeler gauges I use. It would encourage me to check the valve clearances more often.
Old Jan 1, 2004 | 12:34 PM
Road Rage's Avatar
I have one in the garage right now, have had it 10 years. I used it to set the valves on my Dad's Mazda 626 - when I determined that the guys who installed his timing belt screwed it up, and then bumped ignition timing to let it start. Boy was I pizzed. It worked really well - I double checked behind it with the feelers gauges, but once you get the clicks dialed in, it is a snap.
I do not know if this will work with S2000's, but I do not see why not. I have ordered a 1/2" drive 10mm socket to get a feel for the distances.
Old Jan 1, 2004 | 02:02 PM
Destiny2002's Avatar
Old Jan 1, 2004 | 02:39 PM
Road Rage's Avatar
Yes, I saw it in the FAQ section - I would not get the tool I posted if I had your tool either - or Marcucci's. This was really for newbies benefit.
Old Jan 1, 2004 | 02:47 PM
Old Jan 1, 2004 | 04:58 PM
CoralDoc's Avatar
I have no problem using a screwdriver, box-end wrench and 45 deg. feeler guages. Once the valves are adjusted to spec the first time, I find it only necessary to change the adjustment on 3 or 4 valves at each check that I did every 10-15k miles.
Old Jan 1, 2004 | 05:25 PM
Road Rage's Avatar
You are a better man than I, Doc - are you a neurosurgeon? My big mitts get in the way on some of these little critter engines, and I know plenty of mechanics with even bigger mitts than mine. I would think though that for the less mechanically gifted, and perhaps even for pros who need to do this a lot, the tool might be handy. Whether or not it is is something I will probably either find out in a few years, or if we have a Mid-Atlantic group session, perhaps help with someone else's car. Just thought I'd throw it out there, since a number of people (including Marcucci) went to the trouble of producing something along the same lines, screwdriver not included.
Old Jan 1, 2004 | 09:13 PM
RACER's Avatar
I use a Schley #88950 valve adjustment tool. Having the right tool makes all the difference. The jam nuts are pretty far down. It is a lot easier with the tool.
