window problems.........
Old Jun 26, 2001 | 09:30 AM
YeloS2000ShowGrl's Avatar
Default window problems.........
has anyone else had this happen??
when you put the top down the drivers side window gets stuck and doesnt go all the wayy down??? mine has been doing this for the last week or so.........but i am able to put the window down after the top is all the way down though..........i go to the dealership tomorw to get it fixed. just wondering if any others have had this problem?
see yah
<3 jen
Old Jun 26, 2001 | 09:34 AM
bguernsey's Avatar
yea, I have the same problem. If you search the archives it will reveal that this is a common issue with some relay in the door. I still haven't gotton mine fixed.
-B
Old Jun 26, 2001 | 09:45 AM
DaveZ's Avatar
Very common problem. I had to have the motor replaced. Call your dealer before you go in so that they can order the part. Took mine about a week to get the part but I recall others saying that the dealer got it overnight.
Old Jun 26, 2001 | 09:57 AM
i made the appointment at the dealership about a week ago so they should be ready yah know? but if they arent i wouldnt be surprised either, i called them again today cause yesterday on my drive home from viginia my maintnence required light came on and i have no idea why........so they are gonna have to do somethig.
<3 jen
Old Jun 26, 2001 | 10:19 AM
MHK S2000's Avatar
<3 jen
How many miles do you have on your car? I believe the 'maintenance required' light comes on as a reminder at around 7500 miles, if I'm not mistaken.
Old Jun 26, 2001 | 10:40 AM
DJ Qube's Avatar
[QUOTE]Originally posted by YeloS2000ShowGrl
[B]has anyone else had this happen??
see yah
Old Jun 26, 2001 | 10:56 AM
Sondra S2K's Avatar
Mine's in for the MAP sensor right now and I asked them to fix the window too... they can't replicate the problem, but it does it to me 4 times out of 5!
Old Jun 26, 2001 | 10:59 AM
DaveZ's Avatar
Mine stopped and started irregularly. It appeared to go week by week until I had it fixed. One week it would not work consistantly, the next week it would work. If yours had the problem and seems to be fixed all by itself, my bet is that the problem will reappear.
Old Jun 26, 2001 | 08:41 PM
it works then doesnt work it is very annoying, and i have 6050 miles on the car, i have already gottten an oil change already too at i believe 4500 miles or so........i will find out the deal tomorw though and let yah ll know whats goin on,
<3 jen
Old Apr 3, 2013 | 02:31 AM
Kris9912's Avatar
Problem - Passenger side window doesn't go up or down using either switch. However, it does go down when you put the roof down just fine - it just won't go back up again! I've checked every single fuse just to make sure and there all fine so assume its a problem with the wire?
Just before this I noticed this I did replace the fuse for the power socket and radio, so it might be nothing but more than likely a coincidence. Any help would be much appreciated as I can't have my roof down at the moment in case it rains and I can't get the window back up!!
