Please help. Bent Xbrace and crossmember.
Old Mar 22, 2004 | 12:45 AM
1FastS2k's Avatar
Default Please help. Bent Xbrace and crossmember.
To make a long story short, I hit a large rock and tore some things up. It hit the front drivers side of my Whiteline front brace and RIPPED the bolt out and bent the bar back. Any suggestions on what exactly needs to be replaced and tips on how to do it? I'll try to get some pics posted later. Thanks!
Old Mar 22, 2004 | 02:46 AM
honda9krpm's Avatar
if the brace is bent you will need a new brace
the material is very fragile and will break if you try to bent it back
the other stuffs can be removed and straithen out with a hammer
take a pics and will try to tell you more
good luck with the repair
Old Mar 22, 2004 | 08:50 AM
1FastS2k's Avatar
I'm definately going to replace the Xbrace, I'm just concerned w/ the front crossmember. I looked it up and it's about $500. I just haven't had a chance to figure out if the whole crossmember needs to be replaced, or if I can just separate it into different parts and replace the broken pieces. I'll try to get pics tonight.
Old Mar 22, 2004 | 09:55 AM
redsound's Avatar
[QUOTE]Originally posted by 1FastS2k
Old Mar 22, 2004 | 12:30 PM
1FastS2k's Avatar
also, everyone else... be prepared to cringe, it's pretty mangled.
Your such a confidence booster! Actually, I'm glad you pointed out the exhaust dent too. So, the exhaust is dented, the Xbrace, the rear tie bar, and the front crossmember. Do you think insurance might cover this?
Old Mar 22, 2004 | 12:36 PM
redsound's Avatar
Old Mar 22, 2004 | 02:58 PM
dms2k's Avatar
Here is some crappy pics of the the x-brace
Old Mar 22, 2004 | 03:47 PM
1FastS2k's Avatar
Thanks for posting the pics Dustin.
Old Mar 22, 2004 | 04:02 PM
honda9krpm's Avatar
looks like a job for the hammer and some touch up welding
consider yourself lucky that you had the brace on
BTW I did the same thing not too long ago
Old Oct 2, 2006 | 08:57 AM
Project SSAP1's Avatar
back from the dead ...i have the EXACT same problem...did u end up having to purchase an entire new crossmember? or did u just fix it?
