what is the best transmission fluid for a s2k
i got my s2k a month ago, trying to change the transimission oil and rear differential oil, i know the mobil 1 is good for the rear diferentail, but what about the trany? which one is the best honda OEM or redline? where can i get them online for a better price?
thank you for all the replies!!
The majority of people on this board run the honda MTF HG fluid for their trannys. This fluid is designed specifically for Honda and Acura transmissions. It is a fortified 10w-30 motor oil with special additives for smooth gear changes.
I just changed mine last night.
HONDA MTF only for tranny!
As for rear diff, switch to LE607, it's better than Mobil 1. I'm using Mobil 1 now, but I will be switching to the LE607 (you can get it from Rick's - see link on site).
those of you that say use HONDA ONLY...have u tried others to base ur suggestion upon, or are you saying HONDA ONLY because you are satisfied and HAVE NOT tried others?
Originally posted by mugenpower_s2k
thank you for all the replies!!!
i still want to know what is the diference between OEM MTF and redline MT-90?
thank you very much!
I just know it works.
