Mark this thread as Sold
pioneer 4 ch amp gm-x364
just upgraded to a better amp.. have the orig box (i think) plus the manual figure $75.00 plus shipping
picture taken from the web but i can post some actual pics once my camara batteries are charged..
here are the specs listed off the web..
Features
PWM Regulated MOSFET Power Supply
Bridgeable 2/3/4 Channel Capability
Balanced Isolator Input Circuit
Screw-Type Power/Ground Terminals
Screw-Type Speaker Terminals
RCA Inputs (4-Channel)
RCA Outputs
Hi-Volt Input Level Control (400mV-6.5V)
Speaker Level Inputs (4-Channel)
Selectable Crossover: 80Hz, -12dB/oct. (LPF/HPF- A,B Channel)
Specifications
Continuous Power (14.4V): 35Wx4 (4W), 40Wx4 (2W), 70Wx2 (4W)
Max Power (14.4V): 70Wx4 (4W), 150Wx2 (4W)
Frequency Response: 10Hz - 50kHz (0,-1dB)
Total Harmonic Distortion: 0.008% (1kHz, 4W)
Signal-to-Noise Ratio: 100dB (IHF-A)
Dimensions: 11" x 2-5/16" x 9-5/16"
Features
RCA Outputs
Specifications
hey LT
PM sent and i've added some acual pictures
i don't see why this unit would not work with your Alpine head unit. i used it with my Pioneer 640 and it worked fine. on the first picture you can see a pig tail coming off the amp - the reason i used this connection instead of the RCA's for the rear speakers is because my head unit would not allow me to use the fade option if i ran rcas.
I'll double check with some of my local guys who have Alpine units just to make sure for you..
how about this - if for any reason your not satified after the purchase - I'll give you your money back
Hey Bass, (Got your PM as well)
"how about this - if for any reason your not satified after the purchase - I'll give you your money back "
Can't go wrong with that deal. I use the same deal when I sell my stuff to others on the board. Haven't heard one complaint (yet...)
If it's compatible, I would love to take it off your hands.
Thanks,
LT
Thanks,
LT
Thanks John/darkknight,
Yeah, he said he'll ship it out tomorrow, and gave me instructions and recommendations for wires, etc.
I'll just ask my local Mid-A ppl to help me with the install. If not, I'll try to do it myself.
Thanks again,
LT
Thanks again,
LT
LT,
I installed this amp into Bass' car... and I installed his new amp. There is no reason why this amp would not work with your Alpine. If your alpine has RCA outputs. This will work. This amp will even work with speaker line level inputs. You should not have any problems with this amp. Bass is a stand up guy and I'll vouch for him 100%.
vodalus
Feb 13, 2003 08:07 PM
