Parking in gear
Old Apr 30, 2004 | 06:11 PM
PMantis24's Avatar
Default Parking in gear
Ok, after reading some on the handbrake threads, it's time for me to park in gear.
One problem... how? please bear with me, I'm a manual tranny noob. I can drive the car fine, but can someone give me the steps to park in gear. Thanks.
Old Apr 30, 2004 | 06:13 PM
dut's Avatar
dut
- park the car, turn off car, put it in gear, done
Old Apr 30, 2004 | 06:54 PM
mxt_77's Avatar
Just don't forget that the car is in gear when you start it.
Old Apr 30, 2004 | 06:57 PM
hygiene boy's Avatar
Parking in gear locks up the transmission so the wheels don't roll. You wouldn't leave an automatic in neutral, you put it in park. Put it in gear , while the clutch is still depressed turn off the car.
Old Apr 30, 2004 | 07:07 PM
mxt_77's Avatar
Originally posted by hygiene boy
Don't forget to step on the clutch again before you start it up.
The car won't start if the clutch pedal isn't depressed. The problem occurs when you start the car, then let the clutch out without taking it out of gear!
Old Apr 30, 2004 | 07:18 PM
RED MX5's Avatar
[QUOTE]Originally posted by mxt_77
Old Apr 30, 2004 | 07:26 PM
Young_R's Avatar
park it in 1st gear if your front is facing uphill
park it in reverse if your front is facing downhill
Old Apr 30, 2004 | 07:30 PM
Nero's Avatar
The thing is, I don't think the uphill downhill thing really matters. As an experiment, I was on a sharp downhill slope and I put it in first and reverse and they both held. Just make sure you only use those two gears, the others won't be able to hold your care enough.
Old Apr 30, 2004 | 07:35 PM
PMantis24's Avatar
Thanks guys I see a couple of methods mentioned, so I assume they all do the same job safely.
Ok, here's what I got.
- Pull into spot or final resting place
- While stopped, pull handbrake
- Put car into first (clutch still depressed)
- Turn car off
- Release clutch
Warning: Don't forget car is in first when starting up again
Old Apr 30, 2004 | 07:37 PM
Young_R's Avatar
[QUOTE]Originally posted by Nero
