Thermostat Removal Basics?
Old Dec 9, 2000 | 06:10 AM
Prolene's Avatar
The Honda repair manual gives no step by step info on this, only a picture of where it is and bolts. Looks like I might have to take off the ac compressor to get enough room to take thermostat out. I recall someone having replaced it and said it was a bear to do. Anyone with info on technique.
Thanks in advance.
PS: Due to the inadequacies of the Honda manual, I ordered a Helm manual today.
Old Dec 9, 2000 | 06:42 AM
cdelena's Avatar
I thought they are the same.
Old Dec 9, 2000 | 06:53 AM
Big Al's Avatar
I also believe they are the same.
Old Dec 9, 2000 | 07:24 AM
CoralDoc's Avatar
Also, I'm curious about why you want to remove the thermostat. I thought that it is an important part of the warm-up cycle in a car, and keeps the engine operating at an appropriate temperature. Am I missing something?
Scott @ King Motorsports's Avatar
Hi Folks,
Removal of the thermostat is not difficult. It must be done from the bottom however. No need to remove any other parts ie, compressor etc. A 12" extension with a swivel aids considerably. Don't forget to drain the radiator first.
Good Luck!
Old Dec 9, 2000 | 10:01 AM
cdelena's Avatar
Scott is right, but unfortunately I figured that out before I read his post.
I only had a little time today so I thought I would do something quick, like installing the Mugen thermostat. I should have installed the header, it would have been faster. Two hours later and I am educated.. don
Old Dec 9, 2000 | 04:08 PM
Prolene's Avatar
Thanks all for the posts. Just got to them. The header is in and like Pinky said, the engine does run more smoothly. I am pleased. I will try to get the thermostat housing out as described. I was trying to get it from below, but could not see the upper forward bolt. I think I will have to do it "blindly".
CoralDoc, I want to replace the thermostat with the Mugen one I received. Should not be without a thermostat, for sure.
Old Dec 9, 2000 | 05:40 PM
CoralDoc's Avatar
Aha! So, thermostat replacement. Good luck with the R&R and let us know how you like the Mugen stuff.
Old Dec 10, 2000 | 01:03 AM
Prolene's Avatar
Following Cdelena's advice, I was able to see both bolts and change the thermostat using a hand on either side of the engine mount technique at times. The car runs fine; can't say it's peppier for it just yet, for the headers already made an improvement.
Old Dec 11, 2001 | 07:11 AM
Pinky's Avatar
[QUOTE]Originally posted by Prolene
[B]Thanks all for the posts.
