Deprogramming OEM optional remote?
Old Aug 22, 2004 | 01:41 PM
revhi's Avatar
Default Deprogramming OEM optional remote?
Here what happened. At HIN in Philly, my girlfriend locked her key and remote in her trunk. She had her valet key in her ignition, but locked the glove box. To open the trunk I programmed my remote to her car.
Now I can't deprogram my remote. Everytime I hit my remote it locks and unlocks both our cars. I tried programming just her remote over again for just her car and than mine for my car, but still my remote opens both.
Anyone else have any ideas?
Old Aug 22, 2004 | 03:24 PM
alpines2k's Avatar
The remote is a transmitter, not a reciever. So the car is actually responsible and not the remote.
I'm sure someone knows how to fix it, or try calling a dealership.
Old Aug 22, 2004 | 03:37 PM
xviper's Avatar
You almost had it. You should have kept going. The receiver can store up to 3 separate transmitters. When you program a 4th, the 1st one is kicked out. Do the programming using the girlfriends remote one more time to see if your transmitter quits working. Do it one more time if it still works.
Old Aug 22, 2004 | 05:02 PM
revhi's Avatar
So basically the car will store the same remote more than once? So should I keep doing the same one until it knocks mine off?
Old Aug 22, 2004 | 05:18 PM
xviper's Avatar
In "theory", yes, but in reality, who knows? Give it a try. It's only a few minutes of your time. If it doesn't work, then go to the dealer and ask them what to do.
Old Aug 22, 2004 | 08:10 PM
steven975's Avatar
actually when i was programming a new remote, the old one stopped working.
I used the instructions from h-and-a. When the car goes into "learn" mode, you hit the buttons on all the remotes you want to use. In my case, I didn't hit the button on the old remote and it got deleted.
Old Aug 23, 2004 | 05:21 PM
revhi's Avatar
Ok it worked. I just kept programming the same remote a few times until mine got knocked off.
Old Aug 23, 2004 | 08:23 PM
xviper's Avatar
Old Aug 25, 2004 | 06:41 AM
stocks2k's Avatar
You might want to program your wife's 2nd remote again as well just to be safe. I bet that one got removed as well.
Old Aug 25, 2004 | 05:19 PM
revhi's Avatar
My G/F lost her 2nd remote a while ago.
