ECU Codes
Old Aug 22, 2001 | 01:55 PM
InsaniT's Avatar
Default ECU Codes
Is there an ECU code that gets recorded when you hit the rev limiter and/or overrev that car? My car's at the dealer and I want to know if they can see how the car's been "driven".
InsaniT
Old Aug 23, 2001 | 05:25 AM
joe_s2k's Avatar
InsaniT
Neither of those events will trigger a check-engine light unless some damage was done during the "over-rev". Why do ask? Nervous?
My mechanic said that the over-rev can be identified once they open up the valve cover.
Old Aug 23, 2001 | 08:25 AM
UCrazyKid's Avatar
Over revs, hitting the rev limiter, stalling the car, hitting the top speed limiter. All these do not turn on a check engine light, but are recorded in the ECU and can be retrieved by the dealer. I am not aware of a way to clear these with out the dealer computer tool. This is all part of OBDII. OBDI had it too. I remember getting a call from my mechanic with my Jetta VR6 (when out of warranty, private mechanic)
Mechanic:"Andy, do you redline your car?"
Andy: "Ah, no. Why?"
Mechanic; "are you shure you don't redline your car, (hint, hint)"
Andy: "Oh, well maybe once or twice..."
BUSTED!
Mechanic: "Look, I don't care what you do, I just need to know so I can give you the best service, I'm not VWofA."
So as you can see, they will know.
Andy
Old Aug 23, 2001 | 09:37 AM
joe_s2k's Avatar
[QUOTE]Originally posted by UCrazyKid
[B]Over revs, hitting the rev limiter, stalling the car, hitting the top speed limiter.
Old Aug 24, 2001 | 12:54 PM
bbsilver's Avatar
I'm not sure about the rest of the scenarios and I'm not even positive on this car. I do know for a fact that on Z28s the redlines are recorded in the ECU.
Old Aug 24, 2001 | 01:06 PM
jschmidt's Avatar
[QUOTE]Originally posted by bbsilver
[B]I'm not sure about the rest of the scenarios and I'm not even positive on this car.
Old Aug 24, 2001 | 01:10 PM
UCrazyKid's Avatar
joe_s2k
Trust me, they don't have to open you motor to know you redlined. The computer tattles on you. I was told in the previous experience, not from a dealer it was an independant mechanic/friend, and told by Honda that the S2000 will store redlines in the ECU.
AA
Old Aug 24, 2001 | 01:27 PM
drogers's Avatar
So I guess the obvious question is, how can one reset or erase the ECU?
Old Aug 24, 2001 | 02:07 PM
twohoos's Avatar
Well, conventional wisdom is that disconnecting the battery for 15 minutes or so will "reset" the ECU...but there are lots of types of RAMs/ROMs/PROMs that might preserve a "redline flag" even through a reset. Anyone with an OBDII tool care to do some experiments?
Old Aug 24, 2001 | 06:40 PM
Utah S2K's Avatar
[QUOTE]Originally posted by jschmidt
[B]
I'm no expert on this but I think that (on the Z28) non-repeating
