Throttle adj/ Idle speed . . .Ahhhh Better
After the hot days of the summer, using the AC and other electronics in the S2000, I got a bit perturbed about the Idle dip when the AC compressor kicks on.
old Idle was at 1000 rpm and the AC would make it dip to 600 rpm, sometimes stumble and one time even stalled on me!
I re-adjusted the TPS to just over the idle threshold and had to adjust the idle stop screw to bring down the RPM to about 1400RPM. I also took up some slack in the throttle cable and am now enjoying a VERY responsive car!
It seems that the ECU reads a closed Throttle plate and cuts back its brainpower (prolly for the LEV status) and so if your stopped at a light or something you may get a little bog off the line during a regular 'launch' I had gotten in the habbit of pre-revving the engine to get the ECU out of that 'suspended' state but now its not needed. The AC will bring the RPM down to a steady 1000 and the engine will no longer bog.
Its almost a different car - NOTICE I do have the bored TB so there might be an issue with that originally but I think I remember the bog a bit with the OEM TB.
You know I could swear it used to dip and then come back up to 1000 but latley it hasnt. Seems that most of my electrical stuff affects Idle speed IE: brake lights/headlight/ and even the AC fan w/ the compressor on.
My S is modded enough to screw up the idle anyway
Iridium plugs gapped at .045/Proflow TB@70mm/Fuel pressure @ 44psi/Insulated intake/K&N filter/Neuspeed EX/Other cool stuff but its a secret
I found the old threads on how to adjust it, but the stock TB does not appear to be adjustable. If those are allen bolts holding it, then the factory must have filled the allen head with solder and put white paint on top of it. They are not coming out!
Originally posted by RT
I wouldn't screw with it, but if you must, then cut a slot with the Dremel (use flat blade screwdriver) and have fun.
Ill get the numbers, and even give a measurement of how much the butterfly is open. Ill have to do it tomorrow afternoon.
I do remember the stock TB having non-user adjustable bolts but mine being the ProFlow re-bore just have regular allens.
You can still adjust the Idle stop screw with I think a 2.5mm allen and a 7mm open end wrench. I gave mine about 1/8 turn.
If you dont mind modifying your car and letting it idle at 1500 RPM then I think its worth it.
