Honda of Japan suggests 5W-40
If I'm interpreting this chart correctly it looks as though it says that 5W-40 is the ideal choice for the S2000 and NSX:
http://www.honda.co.jp/parts/hop/oil/next02.html
Can anyone with translation abilities provide further details? I've tried a babelfish and it won't take.
Does anyone currently use a 5W-40 year round? I know it's an option available to us in the owner's manual but I found it interesting that Honda appears to prefer it over 10W-30.
Some peeps use 5w-40 here in the states. 5w-40 has the flow ability and efficiency of a 5w motor oil and the thermal break down protection of a 40w motor oil.
5w-30 is good enough for me. I don't want the extra additives of the 5w-40. If I feel I need a heavier oil due to higher ambient temps, I will go with the 10w-30.
5W-30 will flow better at cold temperatures, and 10W-30 will have less viscosity extender additives. Unless the climate requires it (temperatures regularly below 20 deg. F), I'd use 10W-30.
The climate in Japan ranges from sub-tropical conditions in Okinawa (similar to Florida) to temperate conditions in northern Japan (similar to the mid-Atlantic states). If you are in the mountains, it gets colder there than lower elevations at a similar latitude.
