FPR Install Help
Old Dec 23, 2000 | 04:14 PM
RT's Avatar
RT
Got the Fito FPR and no installation or tuning instructions what so ever!
Upon inspection I think I got it all figured out. Only thing I wasn't 100% sure about was if the fuel rail side (pressure side) hooked up to the side port and fuel return line off the end. That's the way I hooked it up and it seems to work fine but thought I'd check with you all in case I got it backwards.
Pinky, you got one of these bad boys didn't you? Did anybody else get any paper work with theirs? If so could you post?
Thanks All!
Old Dec 23, 2000 | 04:47 PM
Pinky's Avatar
Well the bottom of the fpr goes into the line comming from the block of the car. from there the fuel line goes out the side and to the fuel rail. One of the other holes gets blocked off and the other has the readout in it.
I take it that you moved the O ring from the old fpr to the new one. I didnt and got a high pressure squirt gun for a fuel rail!
Old Dec 23, 2000 | 05:51 PM
RT's Avatar
RT
[QUOTE]Originally posted by Pinky:
[B]Well the bottom of the fpr goes into the line comming from the block of the car.
Old Dec 23, 2000 | 08:54 PM
Schatten's Avatar
hope this helps with any additional information that you may need.
https://www.s2ki.com/faqs/faq_fprinstall.php
Old Dec 23, 2000 | 10:25 PM
cdelena's Avatar
I found that the leaner settings that dynoed well in warm temperatures did not test well with the cold we have had and moved higher in the pressure range. It is very easy to adjust so will move to the lower range as summer approaches.
Although there are no instructions included, it is pretty hard to get it wrong.. and if you do the car won
Old Dec 23, 2000 | 11:16 PM
RT's Avatar
RT
Chris, nice clean install location! What is your fab'd bracket bolted to?
In the colder weather what pressures are you running? =>45psi? How about the warmer weather setting?
What exactly do you consider warmer and colder?
Sorry for all the questions but I'd rather learn from your experience then re-invent the wheel (or FPR)
Old Dec 24, 2000 | 08:25 AM
cdelena's Avatar
There is a threaded boss on the intake that I used. Just built a bracket to get the height and angle right for the tight spot.
I think I am using a pressure about 49 right now, in the middle of the range (46
Old Dec 24, 2000 | 09:54 AM
RT's Avatar
RT
Chris, do you remember the thread size on that threaded boss? Is your bracket flat or does it offset to the front or back (2-D or 3-D)? Do you remember how far apart the holes are?
Again sorry for the barrage but your installation is by far the cleanest I've seen to date, since I too was worried about the excess length of fuel line.
Is your plan to use 49 psi under 80 deg and 44 psi above? Or do you not know your warm weather setting yet?
Thanks Again!!!!!!!!!!
Old Dec 24, 2000 | 03:07 PM
cdelena's Avatar
Don
Old Dec 25, 2000 | 10:33 PM
RT's Avatar
RT
Thanks for the info Chris! I think I'll have to copy you on that install location at my earliest convenience, hope you don't mind
chubbys2k
Jun 27, 2016 07:01 PM
Xherrox
Mar 25, 2009 08:45 AM
scott2055
Apr 25, 2008 06:25 AM
ItalianBucwheat
Aug 21, 2002 12:15 PM
viscreal2000
Feb 13, 2001 10:44 AM
