CTSC Install -- No Fuel Delivery Beyond FPR
Hi all,
I've been working on installing my CTSC kit and I've run into an issue. The kit has a front mount, if that makes a difference. I got everything installed and went to turn the car over. It just cranked and never started.
I thought it might be the wiring, so I cut out the ESM and went back to stock wiring. Nada.
Upon inspection of the fuel delivery system, I noticed an issue. Namely, fuel was being delivered through the lines by the pump until it met the Comptech FPR. (You could feel the fuel passing through the lines prior to arrival at the FPR) After the regulator, the line contained an EXTREMELY small amount of fuel. I tried adjusting the regulator to allow more fuel delivery and the result was the same. ( I do not think it was an adjustment issue anyway as the previous owner didn't touch the FRP settings) Attempting to start the car with the sending line from the regulator removed from the fuel rail did not yield fuel squiring out of the line.
At this point I thought it might be a faulty FPR, so I re-routed the line and re-installed the stock FPR. Again, cranking the car yielded no fuel spraying out of the regulator. However, if the feed line was removed from the regulator and just left open to drain into a bucket, fuel sprayed out when the pump primed.
Cliff Notes: Fuel is making it to the regulator, but does not seem to pass through either the stock FPR or the Comptech FPR. Has anyone experienced such a problem before? It seems HIGHLY unlikely that both FPR's would be bad.
Almost forgot, does the FPR (either stock or Comptech) use vacuum to function? Maybe I installed some of the vac lines wrong when installing the kit and there isn't enough vacuum for the FPR to function?
The fuel path should be tank - line - fuel rail - FPR- return to tank line. Your description makes it sound like you are trying to add fuel from the FPR.
I'll check that out today. I'm pretty sure we just took the line going into the stock FPR and put it on the bottom of the Comptech one.
However, I have no idea why, after reinstalling the stock one, the engine wouldn't crank as it worked fine before the install.
Thanks for the reply!
if i am thinking correctly you went from the RAIL ---> the bottom of the FMU (return!!!!) instead of the send (on the side!)
hope this helps. if i am not following you correctly please take pictures and we'll get this sorted out!
Originally Posted by dales2000,Apr 20 2008, 02:56 PM
is it possible there is not enough pressure from the pump? maybe u need to switch those two lines on top of the fuel pump?
pump the car would still turn over and run - mine did at least.
We pulled the fuel pump out and
noticed the feed line was almost off from the pump to the top of the holding mechanism. After making sure the hose was tight, we reinstalled. When priming the car, the fuel pump made a higher pitched sound -- a whiney sound. Still, we got no fuel delivery to the fuel rail or the line between the fuel rail and the Comptech FPR. I have no idea what the issue could be....
Faulty fuel pump?
Faulty fuel pump?
forgot to mention that we also made sure that the lines running from the fuel rail to the FPR were correct I.e. That there was a line from the fuel rail to the SIDE of the FPR and a return line on the bottom of the FPR
