narrow band 02 gauge install
Old Apr 18, 2005 | 07:15 AM
03spa's Avatar
Default narrow band 02 gauge install
I saw this topic a while ago, but I cannot find it on the search function. I am hooking up a narrowband 02 sensor to the car. I am trying to figure out which wire on the main ecu I need to tap for the narrowband reading.
Thanks,
scott
Old Apr 18, 2005 | 09:30 AM
03spa's Avatar
I have been searching since making the original post. I found this link, however, I also need an igintion and illumination pin.
I have the pink (o2 sensor wire on the gauge pod) hooked up to the 32p #16 wire. I also have ground and and 12v. The gauge is not working. The gauge also calls for ignition to be hooked up.
http://www.defi-shop.com/product/dg/dg_install.html
thanks again.
Old Apr 18, 2005 | 03:36 PM
Slows2k's Avatar
The car uses narrowband sensors stock. Are you installing a wideband sensor, or a narrowband AF gauge?
Old Apr 19, 2005 | 04:28 AM
03spa's Avatar
I'm installing a narrow band.
I had everything hooked up, power, ground, and O2 sensor cable is spliced in to the blue plug pin # 16. The gauge did not work. However there is also an ignition cable as shown in the diagram in the link above that I think might need to be hooked up.
Any help on figuring out where that gets hooked in would be appreciated.
Thanks.
Old Apr 19, 2005 | 03:09 PM
AusS2000's Avatar
Had me confused. The car has two narrowband sensors. What you are installing is a narrowband gauge to display the primarys signal.
Under your dash is a fuse box which has connectors for +12V, IGN and 0V. You'll need to find one of the many threads that shows which is which.
BoostedPearl
Jan 25, 2018 11:59 AM
superchrgds2k
Mar 6, 2010 08:55 AM
ian_6301
Car Talk - Non S2000
May 11, 2008 11:20 AM
icemans2k02
Jun 27, 2006 08:09 PM
CRX 18
Sep 16, 2003 11:43 AM
