Compression test procedure?
Old Apr 26, 2005 | 02:17 PM
FF2Skip's Avatar
Default Compression test procedure?
From searching, I have learned that I should actually let the car warm up first. Higher temps will yield lower compression numbers, but give a truer read.
Besides pulling the spark plugs, do I need to pull any fuses? When turning the car over, do I need to apply throttle? Any help is appreciated.
Skip
Old Apr 26, 2005 | 05:09 PM
FF2Skip's Avatar
I know it's only been a few hours, but s2ki people have spoiled me.
HELP! I've never done it before and I did not find the procedure in my manual.
Old Apr 26, 2005 | 05:44 PM
SC_Highlander's Avatar
I know you want to disable the fuel system. Which fuse to pull -- that I do not know.
Old Apr 27, 2005 | 08:30 AM
FF2Skip's Avatar
Thanks, Bryan.
Old Apr 28, 2005 | 09:58 PM
PWRMKR's Avatar
WOT
Old Apr 30, 2005 | 06:24 PM
Intrepid175's Avatar
Originally Posted by PWRMKR,Apr 28 2005, 11:58 PM
WOT
Full throttle on the test. Also, pull all spark plugs, you'll be doing it anyway and it'll be easier on the starter motor and battery.
On older cars that have a single coil, you need to ground the ignition system as well but I'm not sure that necessary with the S2000. Anyone know for sure?
Good luck & let us know what numbers you get!
Drive Safe,
Steve R.
Edit: I'm not sure about getting lower numbers with a warmed up engine. I was taught that the heat expansion that the internal parts (ie: pistons and rings?) go through in a warm engine helps everything to seal properly so you should, if I'm right, get better compression numbers with a warm engine than a cold one. Not to mention that with everything warmed up, the internals should be better lubed. Just a thought!
Old May 1, 2005 | 06:08 PM
FF2Skip's Avatar
Again, thank you all. I did not get the chance to do the test before attending the Vintage Spring Fling meet this weekend. Hope to do it tomorrow.
Old May 6, 2005 | 08:15 AM
Jasonoff's Avatar
Banned
In the in-cabin fuse box, by the driver's left knee, remove the 15A fuel pump fuse...
Fuse layout label is on the kick panel.
Old Jan 6, 2006 | 06:28 PM
freq's Avatar
...............and what else?
I just bought a gauge today and am looking forward to using it.
Old Feb 14, 2006 | 10:18 AM
cmrs2k's Avatar
just did this yesterday, its quick and easy and gives you a peace of mind.
I recommend keeping something to jump start your car nearby cause its very likely you could run your battery out turning your motor over so many times.
Mine came to 215-225 across all of them, first glance I'd say this is well in norm. Any second opinions from others that have done this?
