Compression test procedure?
From searching, I have learned that I should actually let the car warm up first. Higher temps will yield lower compression numbers, but give a truer read.
Besides pulling the spark plugs, do I need to pull any fuses? When turning the car over, do I need to apply throttle? Any help is appreciated.
Skip
Skip
Originally Posted by PWRMKR,Apr 28 2005, 11:58 PM
WOT
Full throttle on the test. Also, pull all spark plugs, you'll be doing it anyway and it'll be easier on the starter motor and battery.On older cars that have a single coil, you need to ground the ignition system as well but I'm not sure that necessary with the S2000. Anyone know for sure?
Good luck & let us know what numbers you get!
Drive Safe,
Steve R.
Edit: I'm not sure about getting lower numbers with a warmed up engine. I was taught that the heat expansion that the internal parts (ie: pistons and rings?) go through in a warm engine helps everything to seal properly so you should, if I'm right, get better compression numbers with a warm engine than a cold one. Not to mention that with everything warmed up, the internals should be better lubed. Just a thought!
Originally Posted by SC_Highlander,Apr 26 2005, 09:44 PM
I know you want to disable the fuel system. Which fuse to pull -- that I do not know.
Fuse layout label is on the kick panel.
just did this yesterday, its quick and easy and gives you a peace of mind.
I recommend keeping something to jump start your car nearby cause its very likely you could run your battery out turning your motor over so many times.
Mine came to 215-225 across all of them, first glance I'd say this is well in norm. Any second opinions from others that have done this?
