I bought an electric supercharger!
Now you really didnt think Im stupid enough to actually purchase one of these things, did you!?!??!
Clicky
Do you think theres ANY gain in power from this weedwacker blower motor WHATSOEVER? I mean, any seat of the pants improvment?
I think it is rediculous that they say "civic, accord, s2000" like they are even remotly the same kind of riceburner front drive POS.
Sorry, had to get a few opinions on just how rediculous these things are.
Clicky
There actually is one legitimate electric supercharger. I don't have a link, but i remember seeing one that ran off a seperate battery, and could be used in 30 second bursts, like NOS. Aparently anything that runs off the alternator won't be powerful enough to do any good, but a battery powered one can give u short bursts of power.
You have to think about how much air the engine (specially the S motor at 9 grand) is SUCKING in.
A small electric motor spinning at full capacity is still probably causing serious airflow RESISTANCE (let alone POWER) to that 9K RPM vacuum.
Originally Posted by steven975,May 2 2005, 02:50 PM
i think an electric motor would need to draw about 100 amps to provide any boost.
an electric fan will provide ZERO boost no matter how hard it's spinning or how much air it's moving. the engine is still going to take in what it needs, and an electric fan is really just a hinderance to proper air flow.
a COMPRESSOR is what you need to get boost. the air is COMPRESSED in an enclosed and sealed compressor housing. you can't do that with a fan, leaf blower, or whatever else you think you can shove into your intake.
Originally Posted by Wisconsin S2k,May 2 2005, 09:01 PM
this is the magic phrase right here..... BOOST.
The turbo doesn't pump air into any sealed container where boost builds and then is released. Well that's not technically true I suppose. The "sealed" container is from the turbo inlet all the way to your intake valves in the cylinder heads.
Originally Posted by temin,May 2 2005, 03:56 PM
I'm no turbocharger expert, but last I checked the compressor side of the turbo is just a fan. It is just a fan spinning at 150k rpm.
