Sponsored by:
Sponsored by:
Reight Height
Old Jul 18, 2005 | 03:36 PM
Trip's Avatar
Default Reight Height
Was wondering how much i can lower without having rubbing issues. My setup is as follows
Rear:
16 x 8" + 45 with 245-45 AO32-R Rolled fender Camber 2.5Deg
Front
16 x 7" +35 with 205-50 AO32-R Camber 1.75Deg
The car is running on TEIN FLEX adjusted to the higher spec recommended on the manual. Was wondering if i can lower it to a full 1Inch drop.
Is there any possible way i can fully compress the shock in a test environment with out damaging the car
Re
Trip
Old Jul 18, 2005 | 03:42 PM
Trip's Avatar
Originally Posted by JsAP1,Jul 19 2005, 12:39 AM
You can go 1 inch lower than stock with your setup. I would not go much lower than that due to damaging the fenders on hard turns.
If you go with wider fenders like I did then you can be more aggressive. I have the same offset/sizes you have and am dumped 3 inches in the front and rear. No rubbing issues. My rear camber was -2.6 and my front is -1.6. I am also running Aragosta 12 way adjustables.
Old Jul 18, 2005 | 03:46 PM
ASMspec's Avatar
Like I said dont go to low in the front or you will damage your front fenders.
Old Jul 18, 2005 | 03:51 PM
Trip's Avatar
Thanks JsAP1
Is there a way how you can safely simulate compression without damage ?
Old Jul 18, 2005 | 03:52 PM
Kel's Avatar
Kel
Re
Trip
Talk to vtecvoodoo. He works for Eibach springs and can test your shocks on a shock dyno for free. Koni offers this service as well.
Old Jul 18, 2005 | 03:55 PM
Trip's Avatar
Great Idea, but i live in Europe
SW388
Old Jul 18, 2005 | 04:01 PM
Kel's Avatar
Kel
SW388
See if Eibach or Bilstein in Europe will do it. Both those companies should have the proper equipment.
JayJones
Aug 15, 2013 09:02 AM
mikey430
Jun 10, 2013 04:17 AM
Syn
Jun 2, 2012 06:10 PM
MugenRioS2k
Jan 17, 2010 11:15 PM
latinochino
San Diego S2000 Owners
21
Aug 29, 2008 04:36 PM
