Mark this thread as Sold
FS: One of the most Powerful S2000's in the world!
I am sorry to say, but I am getting rid of the S2000. Too much work to do, and not enough time to even enjoy the car. I put a listing on ebay, so I thought I would put it in here also.
Starting the bidding at $32,000.00
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...item=4569072383
This is Chris Barnes (cjb80) old car. Since I have bought it, we (chris and I) have installed a new GT35R Duall BB turbo for faster spooling, an new 04 fully cryo-treated tranny, and a oil cooler for better engine safety. This is his original description of the car down below.
chrisdrivesafastcar.com
"My original goal was not to race the car, but rather to produce 500 rwhp on pump gas. In that time, I have developed the modifications to the car to produce huge power numbers, and have recently reached my goal. I have poured years of experience and research and development in to producing the machine that it is today.
I have pulled out all of the stops. In it's current form, it will support in excess of 700 rear wheel horsepower with racing fuel. Since the cover story of Turbo Magazine (Aug 2004), a new motor, fuel system and turbo setup has been built and installed into the car. The latest build allows for maximum flexibility in turbo sizing, exhaust systems, and still maintains the A/C lines, which were previously sacrificed.
The turbo setup is configured for maximum power, and the power band surges at 5000 rpm. The pull of this car is amazing, and the sound is unbelievable. The car revs very quickly, and is very easy to drive considering the power output.
The car was painted with the factory color to make sure that it looked perfect for the Turbo Magazine shoot in early 2004. Since then, the car has only seen a minimum of road time, and always kept in a garage. This car has never been in an accident, and the exterior is in very good condition. It has just over 27,000 miles on it."
Modifications:
Engine/Cylinder Head
Alaniz Technologies Ported Head
1.5mm Oversized Stainless Intake Valves
Nitrite Coated Exhaust Valves
Custom Dual Valve Spring Setup w/ Titainium Retainers (will handle 11,000+ RPM)
Engine/Cylinder Block
Ross Pistons 0.020" Oversized Pistons, Banodized Coating
Pauter Rods
Polished and Balanced Crank
Iron Sleeves Installed By Benson
Hand Build With Meticulous Attention To Detail
Turbo/Intake System
4.50" x 18.0" x 12.1" Garrett Intercooler (3" Outlet, 2.5" Inlet)
Custom Stainless Steel Intake Piping
Tial 44mm Wastegate
Tial Blow Off Valve
GARRET GT35R (Dual BB)
Full-Race Exhaust Manifold
T-Band Clamps Used On All Silicone Couplers
Custom 4" Exhaust system
Full-Race Custom Sheet Metal Intake Manifold w/ Velocity Stacks
Erick's Racing 72mm Throttle Body
Steel Braided Oil Feed and Return Lines
Exhaust manifold and piping allows for interchanging turbos to modify the powerband
Fuel System
Aeromotive A1000 In-Line Fuel Pump
Aeromotive Fuel Pressure Regulator
-10 AN Steel Braided Feed And Return Lines
10 Gallon Trunk Mounted Fuel Cell (w/ Sponges)
Barry Grant Fuel Filters w/ Replacable Elements x 2 (before and after pump)
MSD 1080cc Injectors
Ignition System
AEM C2DI Ignition System
Accel Coils
Magnacore Spark Plug Wires
Denso IK-27 Iridium Spark Plugs
Wheel/Suspension
Volk CE28n Bronze Wheels, 17" Diameter, 9"/rear, 7.5"/front
Goodyear GSD3 Tires
Buddyclub Racing Spec Suspension
Corner Balanced, Aligned
Spoon X-Brace
Drivetrain
2004 Cryo-Treated Transmission
Kaaz Rear Differential
Comptech Differential Bearing Cap
Fidanza Flywheel
Competition Clutch Ironman Clutch (4 Puck disk)
Electronics/Tuning
AEM EMS w/ Harness Extension (Mounted Under Driver's Seat)
AEM 3.5 BAR MAP Sensor
Greddy 60mm Oil Pressure Guage
Greddy 60mm Oil Temp Guage
Greddy 60mm Water Temp Guage
Greddy 60mm Boost Guage
Greddy 60mm EGT Guage
Greddy Profec-B Boost Controller
Motec Wideband O2 Sensor w/ Dash Display
Battery Relocated To Trunk
Exterior
Bulletproof Automotive Front Lip
Garage Defend Side Skirts
Clear Side Markers
Carbon Fiber Hood (Top Secret Style)
Rick's Accessories 'S' Badges
497 Rear Wheel Horsepower @ 9700 RPM on PUMP GAS!
Modifications:
Pauter Rods
Turbo/Intake System
Tial 44mm Wastegate
Tial Blow Off Valve
Fuel System
Ignition System
Accel Coils
Wheel/Suspension
Goodyear GSD3 Tires
Spoon X-Brace
Drivetrain
Fidanza Flywheel
Electronics/Tuning
Exterior
Clear Side Markers
Actually, the original rev limiter was set at 10500 rpm. There was a bit of valvetrain noise, so we opted to lower it to 9700 rpm just to be safe. Never had any problems with the redline.... Dynoed the car countless times to get a perfect tune.
Nick
Nick
lol
