block your throttle body coolant
Old Aug 19, 2005 | 04:40 PM
rehile's Avatar
Default block your throttle body coolant
Everyone knows heat sucks power from your engine. Many in our area have replaced the OEM air box with a CAI.
Here is a summer-time mod that, for less than a dollar, will decrease your intake air temperature an additional ~5 degrees fahrenheit -- ball bearings slipped into each of the feed/return coolant hoses to you throttle body. This link describes the install (which takes about 10 minutes), courtesy of hondassport.
There is absolutely no engine bog when the AC is turned on, even at low rpms. It's actually quite amazing.
Just remember to take them out when it's cold enough to turn your heater back on.
Old Aug 19, 2005 | 05:02 PM
S2KPUDDYDAD's Avatar
Tits up great trick
Old Aug 19, 2005 | 05:09 PM
xviper's Avatar
I've considered doing something like this myself but wanted to make it a one time mod and not having to mess with it twice a year when winter comes and goes.
I thought about somehow adapting the same valve that Honda uses on the heater hose that controls the water flow to the heater core. It might not be easy as the hose diameters may be too different.
Old Aug 19, 2005 | 09:35 PM
thetz99's Avatar
Thx for the link. I was scratching my head on which hoses to plug. Great mod!
Old Aug 19, 2005 | 09:36 PM
rsaeini's Avatar
[QUOTE=xviper,Aug 19 2005, 05:09 PM]I've considered doing something like this myself but wanted to make it a one time mod and not having to mess with it twice a year when winter comes and goes.
Old Aug 19, 2005 | 11:53 PM
NFRS2kSi's Avatar
bad thing, about this is that u'll get check engine light in the morning... sometimes.... it gets erritated...
Old Aug 20, 2005 | 04:02 AM
rehile's Avatar
BTW, you should not get a CEL after this mod. I don't think anyone here has.
Old Aug 20, 2005 | 05:37 AM
8BALL's Avatar
Been running this mod for about 10 days now. No CEL here
Old Aug 20, 2005 | 06:53 AM
Chiung's Avatar
2 years - no cel
Old Aug 20, 2005 | 07:10 AM
Hondassport's Avatar
Been running this mod since May 1st. , no check engine light.
