super chargers
Old Aug 23, 2005 | 09:59 PM
calidiana's Avatar
Default super chargers
if i were to supercharge my car, what other stuff do i need to get? (besides the supercharger of course)
Old Aug 24, 2005 | 04:01 AM
Slows2k's Avatar
Moving to FI. This question has been answered before, many times. Take a look at the FAQ , ans try a search.
Old Aug 24, 2005 | 05:00 AM
C45P312's Avatar
I would recommend upgrading your clutch. That's about it ...
Old Aug 24, 2005 | 10:07 AM
SIIK2NR's Avatar
Tool Kit...
Old Aug 24, 2005 | 01:05 PM
JayStyles662's Avatar
I would say upgrade your clucth....But while your doing that you might as well put in a Flywheel and make even some 4.57 gears...Your car would see High to mid 12s if you could drive it right....
If you want advice on parts to get...
I`d Say Js Racing Headers or Toda both seem to work really well
T1R 70mm Exhaust.....
Apexi VAFC
If your comptech charged I would throw and 8 LB pulley on there for good measure and you will have one fast car...Peace John
Old Aug 24, 2005 | 01:46 PM
John_Z's Avatar
Get your car on a dyno to check the A/F.
Old Aug 24, 2005 | 09:38 PM
Halo's Avatar
Old Aug 25, 2005 | 09:17 AM
jal3lee's Avatar
so could you add a s/c without upgrading anything else and you will be good to go? the other stuff, i.e. exhaust , vafc, i would put on after ward if necessary, but if i can get enough together for just the s/c, that would do?
Old Aug 25, 2005 | 09:45 AM
Halo's Avatar
Yes. The two kits out there (Comptech and Vortec) have all the parts you need to get the SC up and running. For you peace of mind, knowing the A/F ratio is in a healthy range, that you're making boost and that your hp gains are in the ballpark, a dyno run is worthwhile. Do some searches, there are lots of posts about the merits of VAFC, various exhausts and so on once you want to do more to your car.
Old Aug 25, 2005 | 11:06 AM
jal3lee's Avatar
Halo.. thanks i would probably plan on ugrading exhaust and an vafc, both are not too expensive especially considering the $4k you drop on an S/C..
