Detailed engine information
Old Sep 23, 2005 | 11:54 AM
brent_strong's Avatar
Default Detailed engine information
Hey, I'm looking for some detailed information on the F20c to do some calculations and also just to learn more about the car. I would like to know some technical specs like the bore size, stroke length, installed headgasket thickness, distance from wrist pin to piston deck, distance the piston is above or below the block deck and rod length if anyone knows this...
This is for some engineering stuff and is basically just doing to be used for theoretical purposes, though maybe someday I could put the information to use...
Also, if there is anything else you think may be of interest, let me know! More info is never a bad thing.
Thanks!
Old Sep 25, 2005 | 08:34 AM
Nothing?
Old Sep 25, 2005 | 04:18 PM
Asura's Avatar
There is a ton of info out there. It all depends on you.
Do a search here and on the web like everyone else does.
Old Sep 25, 2005 | 04:48 PM
Isn't the search on here broken? Maybe it's fixed now. I actually didn't try because I was under the assumption it was broken. I did check through the FAQs in the various forums and didn't see anything.
Old Sep 25, 2005 | 04:58 PM
Also, the only thing google turned up for me was this:
The F20C's bore is 87 mm and stroke is 84 mm.
Old Sep 26, 2005 | 07:24 AM
Voodoo_S2K's Avatar
kleecker
Mar 31, 2007 10:55 AM
HydnHood
Oct 23, 2004 03:13 PM
nastinupe1
Apr 17, 2003 01:15 PM
FlyingPig
Oct 24, 2000 09:42 AM
