What interval I should change my Irridium plugs?
What interval I should change my Irridium plugs? when used in S/C s2k?
I have NGK Irridium installed with SC and it has been almost 10,000 mile since.
Maybe time for change?
(I'm getting little worried after I seeing many failure of Denso Irridiums)
TIA
TIA
The whole idea with using Iridium plugs is that they should last the life of the car. The fact that we've had a rash of recent failures comes as a surprise to all of us. There is no evidence to tell you when you should change them as till now, they never needed changing.
These failures were with Denso, so if you are using NGK, unless there is evidence of failure, again, they should last the life of the car. However, if you were a gambling man, you might want to reconsider using Iridium plugs regardless of brand, but the choice is yours.
On a NA car, it's no big deal, but with a F.I. car, is it worth that gamble?
Originally Posted by spoiled@21,Oct 6 2005, 03:25 PM
You don't have to gamble with the NGK copper racing plugs. You just have to change them every 3k miles.
Originally Posted by folex187,Oct 7 2005, 12:48 AM
I have heard this with the copper plugs over and over again. What makes the copper plugs have such a short life? I really need to stock up on them if I'm going to change them with every oil change.
Platinum is much harder and can resist these events but is a lesser conductor. Iridium is also harder but has better conductivity. It tries to be a compromise between copper and platinum.
sorry if this is a stupid question, but which plugs will last the longest with FI? which ones don't need to be changed frequently? I'm currently running my stock plugs so should I check on them frequently?
THanks
THanks
I would get those out of there if I was you. The iridiums are the ones that until recently (like xviper said) you never had to change. I would still go with those if I were you. I don't know the part number off the top of my head but there is a bunch of threads about it.
