driveshaft question
Old Nov 2, 2005 | 02:18 PM
jamminb's Avatar
Default driveshaft question
just recently i was underneath my S and i noticed that the driveshaft
appears to be slinging grease on the underside of my S.
it is just happening on the transmission side of my driveshaft.
curious if this is normal;if not has anyone else had this problem
Old Nov 2, 2005 | 04:14 PM
xviper's Avatar
Could be the rear seal on the tranny is leaking. However, you did say "grease". The tranny fluid is more like motor oil. The ends of the propshaft have a kind of CV joint. There is grease inside and it could be this joint that is leaking. Unless you can tell us exactly the kind of consistency of what's leaking, it'll be hard to say which is leaking.
Old Nov 2, 2005 | 05:35 PM
jamminb's Avatar
this isn't tranny fluid; it is to thick.it appears to be grease and i believe
it is coming from a joint because there is ring of grease on the under
carriage.this makes me believe that it happens during the rotation of the
driveshaft.maybe at high revs ,NOT SURE. does that help; kind of hard to explain
Old Nov 2, 2005 | 07:30 PM
xviper's Avatar
Then it's more likely from that propshaft joint. Check it to see if you can see a crack or break in the seal. If it's under warranty, get them to fix it.
Old Nov 2, 2005 | 07:37 PM
Slows2k's Avatar
Old Nov 3, 2005 | 08:15 AM
Squeezer's Avatar
I had the same problem. one of the CV joints in the propshaft has failed. Make sure the 6mm hex nuts on the flange are tight, they can loosen easily if weren't installed very tight. Only fix is to replace the propshaft because honda doesn't sell new CV joints and the propshaft is $800 from honda.
Old Nov 3, 2005 | 02:50 PM
jamminb's Avatar
is there an aftermarket propshaft for the S that is lighter.do they make a carbon fiber propshaft for our cars.i figure if they do maybe now would be a good time to upgrade.WHAT DO YOU THINK
also i was curious;what could have caused this.just so you know, there have
been times that i have put my s to the test.i broke an axle at the drag strip
after a clutch dump at about 7k.i had a clutch masters stage three at the time.
i did manage to record a time of 14.1 with just a clutch upgrade before this happened.i guess thats not to bad for my 02S.could the stress from that have caused it to damage the propshaft.
Old Apr 18, 2007 | 12:54 AM
quicksilver1's Avatar
Yeh a company in the UK sell composite propshafts (driveshafts) for the S2000.
Give them a call, i think they retail for
Old Apr 18, 2007 | 01:44 AM
mikegarrison's Avatar
Can they deliver two years into the past?
Old Aug 16, 2009 | 11:19 AM
motoinfantry's Avatar
Arrow
was there a vibrating sound when this hapened? im hoping my tranny isnt trash. i have the grease halo as well but it makes a bad noise.
S2KNJ
Sep 14, 2008 04:32 AM
B-Mir
Jan 31, 2007 10:43 AM
Robbs2k
Jun 2, 2006 08:07 AM
Dolemike
Mar 28, 2005 12:24 PM
Decepticon
Dec 4, 2003 04:23 AM
