00-01 rear window replacement
Old Nov 21, 2005 | 04:29 AM
inner's Avatar
Thumbs down 00-01 rear window replacement
I did the rear window replacement this weekend with my friend. The whole job took us about 6 hours. Neither of us had done this before so we followed the S2000 service manual step by step. It came out perfect. (I'd never used rivets before but the manual tells you the correct size needed- actually the riveting was the easiest part of the process)
I took many pictures during the replacement and I
Old Nov 21, 2005 | 07:42 AM
Cyclon36's Avatar
Wow, that's great that it worked out for you. You should make a how-to thread for others. I know there are hundreds of threads on here talking about if it's possible to replace the plastic window without replacing the top.
Old Nov 21, 2005 | 07:50 AM
gosixers215's Avatar
I would love to know how to do this as I need to replace my rear window as well
Old Nov 21, 2005 | 08:40 AM
Buckeye3d's Avatar
I'd be glad to host the file/s if you want. PM and we can set something up.
Old Nov 21, 2005 | 02:49 PM
530s2k's Avatar
[QUOTE=inner,Nov 21 2005, 05:29 AM] I did the rear window replacement this weekend with my friend. The whole job took us about 6 hours. Neither of us had done this before so we followed the S2000 service manual step by step. It came out perfect. (I'd never used rivets before but the manual tells you the correct size needed- actually the riveting was the easiest part of the process)
Old Nov 21, 2005 | 03:10 PM
afwfjustin's Avatar
Wow that's good news inner.
btw, do you like sigur ros?
Old Nov 21, 2005 | 09:13 PM
BlackNightmare's Avatar
Did anyone host this? im going to be replacing mine soon due to cracked plastic
Old Nov 22, 2005 | 02:31 AM
Buckeye3d's Avatar
I sent him a PM offering to host. No word back yet.
Old Nov 22, 2005 | 07:46 AM
inner's Avatar
The three retainers
The rear window comes off easily once the retainers have been removed
There are two clips on either side which hold the top to the car
You first have to drill the rivets and heat up the Au before you can remove them, you'll get the hand of it after the first two
New window zipped on - takes few tries to get it right
I reused the zip locks
This isolation tape comes new with the window from Honda, make sure the center of the tape is over the center of the window
Old Nov 22, 2005 | 07:47 AM
inner's Avatar
I had so much fun riveting this thing that I forgot to ask my friend to take picture of me doing it
Before the bolts were put on
Pushing the rear trim in through the trunk
And here it is (note the color difference)
